rollingshi59
- Oct 12, 2017
- Duluth GA 30096
- 2020 Mustang GT Base A10
Can anyone recommend me a trusting Roush dealer near GA?
Pmed you. Need to get warranty work done. Head unit replacementWhen you say dealer, are you speaking of getting service or buying a car? I've had experience with the Roush technicans at Wood Folsom Ford in Baxley, GA and Akins Ford in Winder, GA. Both were very knowledgable and did a great job.
I meant blowerIf it is the Sync head unit, most dealers will not have their only Roush technician fix it. Most head unit issues are fixed with a reset or replacement.
Outstanding numbers and trap. The P2 upgrade makes a difference with Heat Soak. I am contemplating adding the upgraded Roush Cooling system in the spring.These numbers were run on my 19 Roush Stage 3 with Phase 2 upgrade on the Roush tune. It’s a 10R80 with 3.55 and Nitto 555RII’s on the rear and Shell 93 in the tank.
74 degrees and +400 DA
1st run
10.78 @ 136
2nd run(25 minutes later)
10.85 @ 135
Very satisfied for the 1st time running this car on the Roush tune. It seems like the larger heat exchanger and revised calibration has not made the heat soak as bad as when they first rolled the 2650 out.
I really think the car can possibly hit 10.6’s on the Roush tune.
Wow. Very, very impressive! Great numbers brother.These numbers were run on my 19 Roush Stage 3 with Phase 2 upgrade on the Roush tune. It’s a 10R80 with 3.55 and Nitto 555RII’s on the rear and Shell 93 in the tank.
1st run
10.78 @ 136
10.85 @ 135
I seem to remember that the RS3's have a different CAL then the P2 GT's. May be the reason for his higher trap speeds.Unless Roush has a newer calibration that I am unaware of, the best I ever ran was 10.89 @ 129 on the latest P2 tune.
