Azul Assasin
Also if your looking to get an amazing deal on injectors or interested in the fuel system I built I can get you great deal.
This is the only dyno sheet I have and like I said I wanted to have track numbers before I posted. That's why I waited so long to post this. I didn't get a chance to get to the track this year but I will when it opens up again next year.Those are STD uncorrected numbers, do u have the SAE corrected numbers?
Like to see the difference? Again this isnt a dig, truly just curious.
One things for sure, E85 is the way to go
Very nice man.I was tuned on a dyno here in Michigan but PBD is the tuner. The mods are just the basic bolt ons. I have Kooks 2" primary headers and Kooks catback x-pipe exhaust. ID1050x injectors and a custom fuel system I built using a Deatchwerks x2 fuel hat. Two DW400 pumps -8 feed -6 to stock feed for return.
Need some advice on the tire set up.
Thinking of running g2 on front and NT555RII in rear.
Im debating between 19s street set (19x10, 19x11) and drag set . My daily driver and it will see rain. possibly vms set up (18x9.5, 17x10).
What are yall thoughts? is it going to be more dangerous in rain with vms set up?
Understood. I am aware off 100 rating. But my initial question was comparing between 17x10 and 19x11 both 305s in rain. Possible difference will be the sidewall depth and will that make a difference in rain?I hate to say it, but sometimes we have to bite the bullet and buy two sets of wheels and or tires based on how we plan to drive the car.
I will say that some people don't realize the 100 rating on the NT555Rii means it wears pretty darn fast when used as a daily. If you get much more than 8,000 miles on them, consider yourself pretty lucky but they will mostly likely be pretty much finished by that time.
Having said all that, I do have the NT555Rii but recently switched to my second set of wheels/tires, since I really can't get the heat into the Nittos to allow them to do what they do best in the cooler weather......on the street.
I don't think you will notice a difference in the rain. You will notice a difference on dry pavement though with more sidewall.Understood. I am aware off 100 rating. But my initial question was comparing between 17x10 and 19x11 both 305s in rain. Possible difference will be the sidewall depth and will that make a difference in rain?
You will still have your stock wheels and tires? I'm sure if you broke an axle or something they could say it was related and not cover it. If you blow up your engine that's not related to DRs. My suggestion would be don't take it to the dealer with the DRs on the car. It's not hard to just switch the wheels back. I doubt that roush would deny the claim either way though.Possibly know if Roush voids warranty with radials on?
Makes sense. Couldn't think about swapping back to the stock wheels. When my kit was installed, tech told me that I must bring the car back if I get the wheels and tires changed. Didn't ask why but I assume there is no performance effect other than speedometer?You will still have your stock wheels and tires? I'm sure if you broke an axle or something they could say it was related and not cover it. If you blow up your engine that's not related to DRs. My suggestion would be don't take it to the dealer with the DRs on the car. It's not hard to just switch the wheels back. I doubt that roush would deny the claim either way though.
I don't know why he would say that but you don't need to bring it back to them for wheel and tire changes. I wouldn't take the car back in. I would only bring it in on the stock wheels and tires. If the tire diameter is close it won't change the speedometer.Makes sense. Couldn't think about swapping back to the stock wheels. When my kit was installed, tech told me that I must bring the car back if I get the wheels and tires changed. Didn't ask why but I assume there is no performance effect other than speedometer?
