Matthewstorm
Sorry, I should have said highest for a 2021.
The 18-20 yeah do run those numbers. I have yet to see or hear a 2021 run that high.Um.
2019.
Wow those stock numbers seem super low too. Almost 20% parasitic loss seems a bit much. But make the improvement look even better.here is what was in the folder with my warranty stuff
Just had the same code pop on mine with about 400 miles on the SC.finally took delivery of mine last wed.
What should have been a fun drive home from Cincinnati to Charlotte turned into a pain because it was raining most of the way but that was probably best for engine break in anyway.
Dyno sheet shows 619.8 to the wheels post install and 374.5 pre install. The install took place after the latest tune update from Roush.
700 miles in and i decide to let her eat a bit and it triggered a check engine light. I pulled it into the shop and scanned it right away and got a random misfire code. Also a code for AC out side of normal testing range or something like that. The engine bay did seem to have a lot of heat in it. temp guage and oil temp guage were both in the center so there was no over heat. i cleared the code let it cool and drove home easy.
plan on taking it to a roush dealer sometime next week.
You have the updated tune?Just had the same code pop on mine with about 400 miles on the SC.
Mine was installed on May 28th so it has the 2nd revised tune supposedly.You have the updated tune?
So, what happened?Mine was installed on May 28th so it has the 2nd revised tune supposedly.
WOT passes on the highway it came on with out me knowing Ford pass sent me a notification. Stopped at a gas station for gas and when I left it had no check engine. About a half mile down after half throttle the light kicked back on. Drove back home with partial power as not to break anything.So, what happened?
