twold
Just had a beautiful sunny day at Long Marston dragstrip.
Last year same track N/A with zero mods and I managed 13.34/107 mph
This time with Whipple stage 2, stock UK headers ,Whipple tune,stock wheels but MPSS rears fitted last week,cradle lockout (helps stop wheel tramp).
First run was in Standard Auto mode and managed only a disappointing 13.08/113mph ,so a slight improvement on stock time and 6 mph up on terminal speed compared to last years N/A attempt .
Last 2 runs were much better though.I used Auto Sport mode this time (NOT track mode) and managed a best of 12.85/119 mph.
Traction off the line (and my ineptitude) were a problem though after going to Sport Mode and I think at least half a second to a second was lost there and this could have affected the terminal speed by 2-3 mph maybe .I dropped the tyre pressure a very small amount after advice from the locals but apparently nowhere near enough.It needs to be very visibly lower to make a difference apparently.
So......Yes after the Whipple install it is faster at the track....it actually felt much faster than the timeslip suggested to the degree that while driving back to the pits I half expected a crowd to gather around my car after the runs applauding and looking on in awe.....sadly they did not:hail:.
Gibbo for example has managed only a few mph/tenth less than this without FI ,and much much less money too.
Having said that It does 'feel' so much faster than stock at the track and just keeps going and going .I could not consider going back to stock now even though I have reservations about the crazy money that I have spent for relatively small gains on paper.
Importantly if you are contemplating FI ,firstly don't believe all the hype and exaggeration that is out there and then you will be fine.
Whipple Stage 2 /72 lb inj/132mm Throttle body/3.75 Pulley/6 rib belt/boost gauge . OPG/TG. BMR Cradle Lockout/Steeda adj Diff kit/Steeda IRS subframe align kit. Roush axleback.Spacers F25mm R21mm.Stock wheels/ P Zero front/MPSS Rear.Undersealed.
