Brad1810r80
- Jul 22, 2021
- Huntsville AL
- Brad
- 2018 Mustang 2018 F150
Am I the the only one that has bad vibrations with the QA1 10r80 carbon SFI driveshaft. After about 55mph mines vibrating pretty bad. Seems like I just pissed away $1700. Installed per instructions torque correctly and all the lines colors match up.
If I was to rotate it, I assume I need to remove the shaft then flange . Reclock the flange 180 to rear end then install the shaft with all the lines matching??
