Push starting
16Fastback
RMR 8985
Pennsylvania
Stephen
2016 Fastback , 2009 Ranger 4x4
Can these new cars be started by popping the clutch?
Semi
Utah
79 ford f250 7.5l/2015 gt pp ruby red
I don't know, pushing the button wakes the thing up. My guess is no.
16Fastback
16Fastback
RMR 8985
Pennsylvania
Stephen
I would think that the battery would have enough power to wake the system up,I was just wondering if it didn't have enough to crank the engine could the car be started.Thanks for the reply's
scott_0
Oxford, Pennsylvania
the push button isn't black magic, or some sort of sorcery, push the button and commence with proper push start steps
Chef jpd
Brooklyn, NY
If the battery is below a certain voltage, no systems will turn on.
So if it is too dead to crank, it would probably not "turn on"
16Fastback
16Fastback
RMR 8985
Pennsylvania
Stephen
Well it looks like this hasn't happen to anyone and with the battery saver circuitry it probably won't,I'm old school and done it in the past so I thought
I'd throw out there.
whalesalad
Costa Mesa, CA
2016 GT PP
Like any other car you gotta have at least the power on (ACC enabled) in order to do a roll start.
You can roll start it if you press the engine start button without pushing in the clutch (to activate accessory mode) then roll down your hill and drop the clutch and boom it will start up.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
The only reason to push start is when the starter is dead. Otherwise, jump start.
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
Yes, you can push start the newer Mustangs as long as you have ACC power (car on).
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2019 Mustang GT Premium+ PP 6spd
Car manufacturers need to start including hand crank starting again.
arghx7
cold
50 years Ecoboost
I can't say I've ever tried this on my 2015. Most new cars won't let you do it.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
Same reason motorcycles don't kick-start anymore...
compression is too high. If you don't have enough energy stored in the flywheel to push the piston past TDC before that spark fires and the A/F mixture pops... goodbye arm.
