andrewtac
vortech will give you credit for the JTB on a YSIB; also I've added some nitrous to help with IATs, well and the added power; something else to consider.
I considered this when i sent the JTB for a rebuild. But honestly, the YSI isn't such a big upgrade. I'd like to see what the JTB can provide and take it from there. Going to have all my money tied up into this engine anyway now.vortech will give you credit for the JTB on a YSIB; also I've added some nitrous to help with IATs, well and the added power; something else to consider.
I was looking at these and they only have vikings identifications on themOP - what length/weight springs are you running on the front coilovers?
I got a ysib in a package deal from beefcake (a bunch of his used parts). I probably wouldn't have gotten one otherwise as I don't expect much difference either. I do plan on doing either back to back dyno or 1/4 mile runs at some point to compare. Probably keep one for a spare.I considered this when i sent the JTB for a rebuild. But honestly, the YSI isn't such a big upgrade. I'd like to see what the JTB can provide and take it from there. Going to have all my money tied up into this engine anyway now.
there's no one to blame but myself. I knew i was pushing the intercooler limits and having higher IATS. It was good on the dyno but im sure real world conditions created some hotter temps and it probably had just a single degree too much timing.Surprised to see the engine fail as quickly as it did. Sorry to see that.
Was not surprised to see engine builder immediately say the tune was to blame lol.
I was watching that listing. I considered it. I also considered it when i got my crank support before the owner was selling a ysi also. Just the non billet version. So i passed.I got a ysib in a package deal from beefcake (a bunch of his used parts). I probably wouldn't have gotten one otherwise as I don't expect much difference either. I do plan on doing either back to back dyno or 1/4 mile runs at some point to compare. Probably keep one for a spare.
How much timing was in it?there's no one to blame but myself. I knew i was pushing the intercooler limits and having higher IATS. It was good on the dyno but im sure real world conditions created some hotter temps and it probably had just a single degree too much timing.
1 degree of too much timing + High IATS + High compression + 22 psi of boost + knock detection turned off= failed ring tension.
I was hoping that i caught it soon enough but sadly, i did not. Now i'm paying for it.
I had the knock detection turned off in the tune due to contastly having false knock issues with the stick shift. Now with the TH400, i'll be able to have a functioning system and a much more efficient engine/intercooler so i highly doubt i'll see issues again. I'll find a weak link somewhere else im sure.
Unsure total timing. I hadnt even raced the car because i knew the mt82 was going to go at any minute. Just some pulls on the highway and what not. Never even reviewed the logs because i thought it was safe. probably hurt it on the dyno or one of the hot summer days when iat was high and i did a pull on the highway. Regardless, i implement a big intercooler and heads to reduce temps for the future.How much timing was in it?
What are you using to tune? Sorry, I wasn't aware it was you!
This post made me go back and check the ARP headstud kit I have getting ready to go into my gen 3 build.Update on the engine; REAL lucky i pulled it. It wouldn't have lasted another hard pull before torching the head or block..
Found that for some reason the MMR/ARP 12mm head stud kit that i purchased came with smaller washers. I was curious in regards to this when i assembled the long block but simply didn't think much of it. Well, long story short. The head gaskets was one good pull away from compromising and the head stud washers were literally counter sinking themselves into the heads..
On another note; The source of copper/bronze in the oil was not identified. So now the JTB will be sent out for a refresh also.. Mains looked perfect. Holbrook also determined that most likey, the noise i was hearing was piston slap because 3 cylinders lost ring tension and began scoring the cylinders. He said there's signed of detonation. I knew the timing was hot but didn't think much of it. Good thing the TH400 will make tuning the car much much easier.. Plus the upgrades with the valvetrain!
That's a beauty. I had that same cooler on my mind, but possibly the non-R unit. The R has more internal bars which means better intercooling at the expense of worse radiator cooling due to less air passing through the intercooler.Got some work done last night. Figured instead of spending money, I'll start installing some of these parts that are building up.
K member is loosely fitted. I plan to assembly everything and torque it all as an assembled unit.
Treadstone 1245R also showed up today. She's a thick unit! I'll be doing a side by side comparison once the vortech IC is removed.
considering my coolant temps on e85 never even reached the middle of the gauge using the 175 reisch t state. I really don’t see having any problems. It’s also a factory performance pack so it does have a slightly bigger radiator. I’ll let you know once I get it all back together.That's a beauty. I had that same cooler on my mind, but possibly the non-R unit. The R has more internal bars which means better intercooling at the expense of worse radiator cooling due to less air passing through the intercooler.
My car is street car first that will be used with the A/C on in the summer.
I'll be interested to hear your thoughts on the 1245R though. If the 1245R can keep the coolant temps down, ill consider it.
