Procharger Stage 1 Kit is a huge disappointment!
Discussion in 'Forced Induction - 5.0L V8 Engine' started by DiabloStang, Mar 27, 2019.
  1. DiabloStang
    DiabloStang Member
    First Name:
    Vehicle(s):
    2017 Mustang GT PP
    Mar 27, 2019
    California
    #1 DiabloStang, Mar 27, 2019
    I just installed a CARB legal P-1SC kit on my 2017 GT PP mustang and it sucks! I haven't verified the boost pressure, but according to procharger this kit should produce around 8 psi. Below 3500 RPMs the car feels slower then stock and mildly faster above 3500. I had a BAMA race tune with a CAI intake on it before I installed the kit so i'm assuming it had around 400 whp. Throttle response felt great and I could spin my 305 Nitto's in third in the right power band. I'm guessing this kits maybe makes 500 whp. I was under the impression slapping this kit would dramatically improve the acceleration but was sadly mistaken. Has anyone else had this experience? Does anyone know if a custom tune will improve the whp without adding addition components ?
    Martinnfb likes this.
  2. Nagare
    Nagare Well-Known Member
    Vehicle(s):
    2017 Lightning Blue V6
    Feb 1, 2017
    Ft Lauderdale
    3,732
    1,953
    Garage Profiles:
    Below 3500 you're probably not in vacuum so it is just sitting there looking pretty, above that you're going to have boost kick in and that's where you'll feel the difference. Custom tune will 100% improve everything about it, the stock tune it comes with is neutered all around, especially if it's CARB legal.
    Loki-GT, Martinnfb and bjstang like this.
  3. bluebeastsrt
    bluebeastsrt Oh boy
    First Name:
    BigD
    Vehicle(s):
    Boosted 2015 GT Premium.
    May 10, 2015
    New Jersey
    6,690
    5,536
    Rating:
    100%
    3   0   0
    You probably installed it backwards. And it’s sucking all the power out of the engine. Instead of blowing air into the engine.
  4. 80FoxCoupe
    80FoxCoupe Well-Known Member
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,379
    772
    Rating:
    100%
    5   0   0
    Check the bypass valve for correct operation, check for boost leaks, get a real tune. The blower will make power, just have to track down any issues you may have.
    Great first post tho. Kinda trollish but hey I'm down to help folks out, real issues or not.
    AnalogDan, sigintel, Loki-GT and 6 others like this.
  5. OP
    DiabloStang
    DiabloStang Member
    First Name:
    Vehicle(s):
    2017 Mustang GT PP
    Mar 27, 2019
    California
    Haha. I’ve considering this. The kit was super easy to install. I did run into an issue with the vacuum that operates the bypass valve getting pinched though. I’ll upload some pics in a few days.
  6. OP
    DiabloStang
    DiabloStang Member
    First Name:
    Vehicle(s):
    2017 Mustang GT PP
    Mar 27, 2019
    California
    I’m going to install a real boost gauge soon to verify pressure. I’ve tried data logging the the MAP pressures but with minimal success. The PIDs for MAP pressure aren’t that straight forward and have read some post that these aren’t very accurate anyway.
    Besides the small issue with the vacuum line, I believe the bypass value is functioning correctly. I can hear it blowing off pressure when release the throttle and I verified it was working before I put the front bumper back on.
    I realize that it is kinda of trollish, but I spent 6k on this kit and want some answers.
  7. Tommy V
    Tommy V Well-Known Member
    First Name:
    Tommy
    Vehicle(s):
    Jul 24, 2014
    Brookly park Md
    3,651
    589
    Rating:
    100%
    4   0   0
    First their is no map pid you want to log maf.Second if u are only making 8psi u cant expect it to knock u back in the seat.Make sure you inatalled everything correct and get a log to a tuner.There are many guys running 9's with this kit tuned right and running more boost.
    Martinnfb and cobra199711 like this.
  8. fordfred
    fordfred Member
    Vehicle(s):
    2016 Mustang GT...1970 Maverick...2011 F250
    Oct 27, 2016
    Shit can the Procharger tune. I did and picked up 60rwhp with no other change than a real tune.
    Loki-GT and DiabloStang like this.
  9. OP
    DiabloStang
    DiabloStang Member
    First Name:
    Vehicle(s):
    2017 Mustang GT PP
    Mar 27, 2019
    California
    That would explain why I couldn’t find it. I’m assuming the MAP PID I’ve read about was for the ecoboost motors. I did get a chance to log the MAF and notice it was around 83 lbs/min. I’m not sure how to equate that to boost though. Do you or anyone else know of any remote tuners that have experience with centrifugal supercharged s550s? Also, could anyone recommend any dyno tuners in LA area ?
  10. Chopps
    Chopps Well-Known Member
    Vehicle(s):
    2019 GT
    Dec 29, 2018
    Georgia
    From what I read it should be 6.5 lbs on stage 1 and stage II is 8.5 lbs.
    You have a 2017 so not sure what you expected rwhp.
    I just purchased one for a 2019 and after talking to tech I should be around 668rwhp with a p-1x and stage II kit.
    Procharger tech is on these forums maybe they can help you figure it out in the forced induction forum.
    DiabloStang likes this.
  11. growler
    growler Well-Known Member
    Vehicle(s):
    2018 mustang gt pp
    Feb 24, 2018
    Indiana
    262
    143
    0   0   0
    floorboard that fucker and let it eat ..what does 3500 rpm have to do with anything? its a centri.nothing until up top.....and I think your scared to rev it
  12. Kep4
    Kep4 Jaeger
    Vehicle(s):
    '19 Mustang GT PP1
    Apr 19, 2018
    S. Kalifornia
    274
    167
    Occupation:
    HR
    0   0   0
    What did the ProCharger Team say when you called them about this issue?
    Loki-GT, Timeless and Ninjavitis like this.
  13. Ninjavitis
    Ninjavitis Active Member
    First Name:
    Mark
    Vehicle(s):
    2015 GT, 18 GLA250 AWD, 05 Vette, 12 Hyundai Accent
    Jan 24, 2019
    Pa
    43
    This. Check for boost leaks. Turbos are nice because they compensate for any minor boost loss through where the wastage vacuum/boost line is- but superchargers push the same amount everytime and making sure you dont loose any of it is important to getting what the pulley is intending. Anyway, you gotta get up to 5500-7500rpm to get the scary power.
  14. gimmie11s
    gimmie11s Well-Known Member
    Vehicle(s):
    Murica!
    Mar 2, 2018
    SoCal
    1,063
    606
    0   0   0
    83 lb/min means he’s making power and actually close to maxing the MAF.
    Centris just have a soft initial (low rpm) power curve. It’s in the design of the blower.
  15. Jay-rod427
    Jay-rod427 Well-Known Member
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,293
    865
    Rating:
    100%
    4   0   0
    Buys carb EO kit, complains, and then wants to know about tuners to negate the carb EO neutering...:facepalm: all that aside 8 lbs should be a real nice improvement, but that’s at 6800 rpm. Let it rip.
    Zinc03svt likes this.
Loading...
Share This Page
