procharger shudder/shake and belt slip
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
hey fam, looking for thoughts on an issue I’m seeing. I installed a D1x Procharger on my gt350r in December. No problems, I ran it for 1500 miles and then started experiencing belt slip. I only push 9-10psi so I shouldn’t be having slip issues. I retensioned to spec and even replaced the belt. Still slips. Last week I installed a griptec non slip pulley. This helped tremendously but it will still slip under heavy load.
I noticed my tensioner is noisy and constantly moving at idle. Also the Procharger has a shake/shudder to it if I rest my hand on it at idle. I suspect the spring tensioner is bad. Other possibility is bad bearing in the Procharger headunit heating up and building resistance. I’m using the recommended gates belt.
Thoughts? @ProChargerTECH
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
Is this a HO kit or stage 2? How do you know the belt is slipping? are you seeing dust on the pulleys or hearing belt squeal? Take the belt off of the supercharger and spin it by hand, if the bearing is bad you might be able to feel it vibrate or grumble. Is there oil in the Blower?
madlag
madlag
Snake Charmer
NC
Great questions-
Stage 2 kit. When I first noticed the slip, the boost would go past 5 psi and that was at the upper end of the rpms. It really lost its punch. Opened the hood and immediately saw all the dust on the pulley and surrounding area. Checked the unit by hand and it felt normal. There is oil in the unit of course.
Now that the griptec pulley is on there it’ll slip under heavy load, all of the sudden. Usually 2nd gear in a hard pull, the boost will just drop off momentarily by a few psi. Like the belt has “hopped” or skipped if that makes sense.
The tensioner really has a lot of movement in it at idle. Not sure you can tell much in the vid.
SheepDog
Colorado
Dax
Hmm. Can you easily move the tensioner with your hand? Meaning can you easily pull it away from the belt? I would think if the belt is slipping on that Griptec pulley that it would damage the belt almost instantly. Maybe double check that the Procharger crank pulley isn't loose or shifting in some way.
ahl395
Allan
Belt slip on a stage 2 is nearly impossible on a regular pulley, let alone with a special one.
Are you sure there is enough tension on the belt? At its longest stretch you should be able to just about twist the belt 90 degrees.
Make sure the tensioner itself is tightened down. It's a three part system so make sure the main (3/4") tensioner bolt is nice and tight, and make sure the bolt under the brass collar (9/16") is tight.
If all that is good then I would say the tensioner is bad. But that much movement in your video is not abnormal. It could be acting differently under WOT though.
PC 2015
Philadelphia
ordered 2019 ruby red pp1 A10 with whipple stage 2
Do you have the 2 lines lined up on the Tensioner. I use to tighten mine a hair over. I was running a 3.80 pulley on a stage. Witch is pretty much the smallest you can run to 7700Rpm with out over spinning the blower and never had belt slip. So either the Tensioner is bad or you dont have it tight enough. I dont think there is anything else it could be.
madlag
madlag
Snake Charmer
NC
Yes I can move it by hand. It’s noisy too.
Tensioner is tighter correctly. I’m OCD about being within spec on mechanics. I didnt have slip at all until about 1500 miles which is why I suspect the tensioner itself.
I do pretty much have the them aligned. It could go a little further but I’m hesitant to put to much side strain on the crank.
See pics and video and see what you think.
PC 2015
Philadelphia
I bet you need a Tensioner. Going a hair tight wont hurt anything.
JPSTANG
MN
Joe
2017 Mustang GT
Figured I would show you how much mine moves for reference, but I don't know how to put a video on this thing... it does not move near as much as yours though!! mine is one notch above the recommended setting though.
madlag
madlag
Snake Charmer
NC
Thanks bro. I just uploaded to YouTube then pasted the link here. I’d be interested to see.
Can you move your tensioner by hand? Does it squawk at you when you flex the lower belt?
madlag
madlag
Snake Charmer
NC
What size pulley?
madlag
madlag
Snake Charmer
NC
4.88, No, mine makes no noise except for a tiny bit of spring tension noise when it tensions back and forth when I really press hard.
Thanks brother. Is there any tremor or shake to your head unit when you lay your hand on it?
JPSTANG
MN
Joe
2017 Mustang GT
No not really, you can see the tensioner move a little just like yours that's about it.
Edit: ok maybe a little less than yours, I just re watched your vid.
