Procharger Kits - 2015-2017 Mustang ALL MODELS - LA Street Cars
Status
Not open for further replies.
Rick@LASTREETCARS
Los Angeles
lastreetcars.com
Rick
2015 Mustang GT PP - Procharged and Built
LA Street Cars is proud to offer ProCharger products for American Muscle - Mustang GT/GT350/V6 models! Please PM us what you are looking for an you will receive your forum special pricing! Custom kits/tuner kits will take a day or two to quote.
If you find it cheaper...just let us know! For more ProCharger info on the products below, just click HERE or for all models.
BOLT-ON UP TO 300+ HP WITH PROCHARGER INTERCOOLED SYSTEMS AND TUNER KITS!
Building on more than 20 years of forced induction engineering and innovation, ProCharger is the first centrifugal supercharger manufacturer to design and release a supercharger system for 2017-15 Mustang GT's. With an original billet aluminum bracket design and compact belt-drive system, ProCharger P-1SC-1 systems and tuner kits, with highly effective air-to-air intercooling, continue to lead the industry in OEM-style fit and finish, ease of installation, and reliable performance.
ProCharger Systems are supplied with proven tuning calibrations and a handheld programmer set for a 65-70%+ HP (Stage II Intercooled System, 10 psi) or 55-60%+ HP (HO Intercooled System, 8 psi) power gain over stock, running pump gas. Featuring the most advanced and durable superchargers, with the industry's coolest charge air temperatures, much higher power levels are possible with higher boost and custom tuning.
Installation of this system is the easiest of any Mustang supercharger system to date–a customer can install this system in his/her garage with common hand tools in a day. For the collector/lease-owner in mind, the HO system is 100% reversible, with no trimming or cutting to any factory OEM plastics or hardware. As if that wasn't enough, you also have your choice of multiple supercharger and bracket finishes: satin, polished, or our new black finish.
HO Intercooled Systems and Kits Available
Stage II Intercooled Systems and Kits Available
New P-1X/D-1X superchargers now available
High Output Intercooled System with P-1SC-1 8 psi 750+ HP Capable
High Output Intercooled Tuner Kit with P-1SC-1 Specify 750+ HP Capable
Stage II Intercooled System with P-1SC-1 10 psi 1200+ HP Capable
Stage II Intercooled Tuner Kit with P-1SC-1 specify 1200+ HP
*Higher boost levels are available for modified engines. Stage 2 System shown above.
HO INTERCOOLED SYSTEM:
55-60%+ MORE POWER WITH PROCHARGER COMPLETE SYSTEMS AND TUNER KITS
ProCharger's 2017-15 Mustang GT HO Intercooled Systems with P-1SC-1 are supplied with proven tuning calibrations and a handheld programmer set for a 55-60%+ power gain over stock, on 8 psi of boost and pump gas. Higher boost levels and horsepower gains of up to 70%+ are possible with an Intercooled Tuner Kit and custom tuning, and even higher with modified motors.
STAGE II INTERCOOLED SYSTEM:
BOLT-ON 300+ HP WITH 10 PSI OF HIGHLY EFFICIENT BOOST
For modified motors, or racing applications ProCharger offers a Stage 2 system, with dedicated drive system, larger air-to-air intercooler, and a vast range of supercharger head units from the P-1SC-1 to F-1R (1,200+ HP Capable).
ProCharger 2015 Mustang Stage 2 System
The HO and Stage 2 ProCharger systems also give Mustang owners multiple options in both the performance and appearance arenas, with your choice of polished, satin, or black finish for both the brackets and head unit. As well as multiple intercooler sizes to best fit the HP level of the customer.
Installation is the easiest of any Mustang supercharger system to date, and a customer can install this system in his/her garage with common hand tools, in a day. And for the collector/leased owner in mind, both systems are 100% reversible, with no trimming or cutting to any factory O.E.M plastics or hardware.
PROCHARGER 2015-17 MUSTANG GT SYSTEM HIGHLIGHTS
HO System:
55-60% gain with P-1SC-1 complete system on 8 psi, quality pump gas
Up to 70%+ gain with P-1SC-1 tuner kit and custom tuning
Even higher gains possible with modified motors
OEM quality bolt-on design and finish
Belts can be changed without removing supercharger
3 supercharger and bracket finish options–Polished, Satin, or Black
Pulleys can be changed without removing supercharger
No cutting of radiator hoses, or trimming of factory coolant fan
100% reversible
Handheld tuner available
Retains the factory brake cooling ducts
Self contained oiling head unit, with CBC billet gear case and impeller
Stage II System:
8-rib dedicated belt drive system
P-1SC-1 up to F-1R (600 HP to 1,225+ HP)
300+ HP gain with P-1SC-1 complete system on 10 psi, quality pump gas
100% reversible, no permanent modifications, no drilling or modifying
Patented 8" supercharger crank pulley that fastens to the factory balancer
Belts and pulleys can be changed without removing the supercharger
Upgradable to “Red” Race bypass valve
Rick@LASTREETCARS
Rick@LASTREETCARS
Los Angeles
lastreetcars.com
Rick
Every day is a specials day at LA Street Cars!
Let us know what you want...let us quote you...then celebrate!
Rick@LASTREETCARS
Rick@LASTREETCARS
Los Angeles
lastreetcars.com
Rick
All Procharger kits can be customised to your specifications, don't forget. Whatever your power level desires, we can customize a kit just for you and your specific need.
Let me know what you want to build!
Rick@LASTREETCARS
Rick@LASTREETCARS
Los Angeles
lastreetcars.com
Rick
Let me know your Procharger needs! We consult heavily on entire car builds too, so let's make sure you get what you want and need.
Hit me up!
Rick@LASTREETCARS
Rick@LASTREETCARS
Los Angeles
lastreetcars.com
Rick
END OF MONTH
End of month savings now at LA Street Carrs...let me know what you're looking for!
Extra savings for orders placed by 2PM Friday September 29 Pacific Time!
Status
