Advertisement
Preview: Diode Dynamics LED Turn Signal Housings!
Discussion in 'Diode Dynamics' started by Diode Dynamics, Aug 8, 2016.
  1. OP
    Diode Dynamics
    Diode Dynamics Well-Known Member
    Vehicle(s):
    2015 Mustang EcoBoost
    Sep 4, 2014
    St. Louis, MO
    2,128
    713
    0   0   0
    No additional updates to provide at this time, thanks!
    Nick C.
  2. ako12345
    ako12345 Active Member
    Vehicle(s):
    Mustang GT 2016
    Feb 13, 2017
    Warsaw
    I'm also waiting for EU version.
  3. MakStang
    MakStang Well-Known Member
    First Name:
    Makis
    Vehicle(s):
    A 2017 miraculous little beast
    Dec 11, 2016
    Greece
    1,678
    255
    0   0   0
    We are all waiting, LOL!
  4. Sherrodmustang
    Sherrodmustang Well-Known Member
    Vehicle(s):
    2017 Ford Mustang GT
    Jan 14, 2018
    Montgomery, AL
    210
    59
    0   0   0
    #469 Sherrodmustang, Mar 11, 2018
    Update on my so far..
    Seems to be all working correctly.
    I went inside the bumper and ziped tied up the wires to help secure the connections and has all seemed fine since. It definitely had some kinda connection issue on the passanger side in the housing. I guess time will tell, all is good so far...
    Love the look, but wished it matched the DRL in the headlights little closer.. but still looks great!!
    Diode Dynamics likes this.
  5. emericA243
    emericA243 Well-Known Member
    Vehicle(s):
    2016 Ecobeast PP
    Feb 27, 2018
    Philadelphia PA
    372
    179
    Rating:
    100%
    1   0   0
    I have having this same exact issue. Passenger side is flaky. When holding / moving the led board\bulb immitation for the DRL it will come on, as soon as you screw the base onto the housing it goes out. tapping\touching the led board brings it on again until you let go. Defi nitely a short \ wiring issue. I guess i need to talk to diode soon about this.
  6. buzz-dee
    buzz-dee Well-Known Member
    Vehicle(s):
    15 GT Premium PP
    Jul 26, 2016
    Germany
    103
    Hi guys,
    I installed mine yesterday. I checked if they would work before putting everything back together. All was good.
    Today, things started to get wonky. Turn signal sound inside the car was different than yesterday. And sure enough the turn signals were not working at all anymore.
    So I shut down the car, then turned ignition back on. Turn signals were operating normally again. I left them on for more than a minute, no problems.
    When I restarted my car the problems came back. Turn signals would work for about 20-25 times each side before they shut off.
    I can easily reproduce it. Ignition on - all is good. Engine on - turns stop working after 20 on off cycles. The BCM shows a DTC for both front turns: short to ground.
    Thoughts? Any help is highly appreciated. Installation was a PITA and I rather wouldn’t wanna go through it again
  7. DB23
    DB23 Well-Known Member
    First Name:
    Vehicle(s):
    2015 Mustang 2.3T 200A Auto Ingot
    Mar 2, 2015
    NJ, USA
    244
    79
    0   0   0
    Installed these yesterday via removing the belly pan. Bit of a PITA on the passenger side due to the wiper fluid tank, but the drivers side was a breeze. One issue was the blade connectors for the DRL bit passenger side would not snap in for a long time ... but at least I know now it won’t b coming loose based on how hard it was to get in! Shades of the 4th brake light install lol. I also had the deal where the switch was moving to EUR in the socket as the board is a bit long, so like others I just pushed the switch into the housing without attaching it to the socket, then sealed the opening with the socket.
    Looks great, 2 days in working great. Did the rear sidemarkers at the same time, along with the 4th brake light it’s all really striking at night.
  8. WILDB
    WILDB Well-Known Member
    First Name:
    Will
    Vehicle(s):
    2017 GT convertible Oxford White
    May 10, 2014
    Australia
    655
    432
    0   0   0
    Don't suppose there is any change to the above status?
  9. emericA243
    Vehicle(s):
    2016 Ecobeast PP
    Feb 27, 2018
    Philadelphia PA
    372
    179
    Rating:
    100%
    1   0   0
    I opened up a RMA request for my driver side with them today looking for a replacement passenger side.
    Quality of this product seems good for the most part, although id expect a little better Q/A and design for $220.
    1. turn signal bulbs\boards are a big long so when selecting the USA switch on board for that sequence timing and pushing it in the socket, it ends up clicking over to EU.
    2. Wiring inside should looked at getting redone some how as my passenger side has become flaky \ not working as only some leds are dimly lit if at all. Sometimes wiggling the housing causes them to flicker.
  10. JeffreyDJ
    JeffreyDJ Jedi
    First Name:
    JJ
    Vehicle(s):
    '17 Mustang GT
    Dec 2, 2014
    Dallas
    1,192
    264
    0   0   0
    The nice thing about DD is they will work to make any problem right. I'm still waiting a few more months before I spring for this, maybe a v2. I really don't want to have to install these twice :)
  11. emericA243
    Vehicle(s):
    2016 Ecobeast PP
    Feb 27, 2018
    Philadelphia PA
    372
    179
    Rating:
    100%
    1   0   0
    OF course! I totally believe in them and appreciate their quick turn around and above average customer support! I will continue to buy their products and recommend them as a top aftermarket lighting company until they convince me otherwise.
  12. drudge
    drudge Well-Known Member
    Vehicle(s):
    Audi TT RS / GT350
    May 22, 2017
    Germany
    50
    Rating:
    100%
    1   0   0
    #477 drudge, May 31, 2018
    found.
  13. cjldad
    cjldad Well-Known Member
    Vehicle(s):
    2017 GT PP
    Oct 17, 2017
    Richmond, Va
    226
    Rating:
    100%
    1   0   0
    #478 cjldad, Jun 7, 2018
    So I finally installed my turn signals.. They look great and function fine other than the galloping turn signal indicator in the dash.. I thought these were supposed to prevent that.. Am I missing so something?
    Edit.. Seems everything has been fine since the initial galloping.. All is well..
  14. Nicolas52
    Nicolas52 Member
    Vehicle(s):
    Mustang 2016 Ecoboost
    Nov 28, 2017
    France
    Hi Guy,
    did you solve your issues ?
    I've just received mine and was looking for the way you connected it.
    Could you give me some informations before i start the installation ?
    :thumbsup:
    Thanks,
    Nicolas.
  15. emericA243
    Vehicle(s):
    2016 Ecobeast PP
    Feb 27, 2018
    Philadelphia PA
    372
    179
    Rating:
    100%
    1   0   0
    Been a month since waiting on my replacement...
Loading...
Share This Page
