DFB5.0
Takes all sorts I guess?
Have you tested water from other parts of Th Cow? Could be risky if the bovine is frisky.
Here you go. This should be just about everything:
Hose reel:
https://www.amazon.com/dp/B004E3W4QW?ref=ppx_yo2ov_dt_b_product_details&th=1
Shelf:
https://www.amazon.com/dp/B086ZDYG8...pY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
Stainless 90 deg for outlet of Active 2.0 to jumper hose:
https://www.amazon.com/dp/B07DP95QWG?ref=ppx_yo2ov_dt_b_product_details&th=1
75' hose:
https://www.obsessedgarage.com/products/og-hose-upgrade-kit?variant=41382318637207
3' Jumper hose kit with stainless quick connect:
https://www.obsessedgarage.com/coll...ssed-garage-3-8-high-pressure-jumper-hose-kit
Stainless garden hose quick connects:
https://www.amazon.com/MTM-Hydro-Stainless-Connector-Fittings/dp/B07YM3JTR5/ref=sr_1_6?crid=23TI7K18GVMGI&keywords=stainless+garden+hose+quick+connect&qid=1675278346&sprefix=stainless+garden+hose,aps,221&sr=8-6
Stainless appliance inlet hose (from hose valve to inlet of pressure washer):
https://www.homedepot.com/p/CERTIFI...ess-Steel-Water-Inlet-Hose-WI12SSFM/309398128
Mosmatic swiveling gun:
https://www.obsessedgarage.com/coll...with-quick-disconnects?variant=39171164340375
4.5 opening nozzle kit:
https://www.obsessedgarage.com/coll...tainless-nozzle-4-pack?variant=15889140351048
MTM foam cannon:
https://www.amazon.com/Veloci-Hydro-PF22-2-Foam-Cannon/dp/B083P6D7DT/ref=sr_1_9?crid=3BKQ2GPFQZWLF&keywords=mtm+pressure+washer&qid=1675279132&sprefix=mtm+pres,aps,304&sr=8-9&ufe=app_do:amzn1.fos.006c50ae-5d4c-4777-9bc0-4513d670b6bc
You can also just order the Obsessed Garage kit if you don't want to source individually. I did it piecemeal because I already had the pressure washer, foam cannon, gun, etc. I ran a dedicated 20 amp circuit, but the active will work on a standard 15 amp outlet too. I ran my plumbing inside the wall, then put 2x6's in between the studs so I had something solid to drill into to mount the hose reel and shelf after I replaced the drywall. Not the easiest of projects, but well worth the effort.
Anyone have an opinion on whether the foam cannon that comes with this works well enough? I ordered the pressure washer, and wondering if I should plan on upgrading the foam cannon as well. Ues I can wait till it arrives and try it but figured I would ask.This.
Buy and enjoy.
Active VE52 | 1800 PSI | 2.0 GPM | 13 Amp | Electric Pressure Washer (M22-15 Hose Fitting) https://a.co/d/cBR0nqI
I don’t remember mine including a soap dispenser foam cannon. I had one that works perfectly with the lance and pressure washer. Just used it yesterday!Anyone have an opinion on whether the foam cannon that comes with this works well enough? I ordered the pressure washer, and wondering if I should plan on upgrading the foam cannon as well. Ues I can wait till it arrives and try it but figured I would ask.
UPDATEI don’t remember mine including a soap dispenser foam cannon. I had one that works perfectly with the lance and pressure washer. Just used it yesterday!
Still love it.
Thanks. Ill try it!UPDATE
I did get the rectangular soap dispenser!
Never used it. I’m sure it’s adequate for a wash or two. Give it a shot.
Yeah give it shot. I have the Adam’s foam cannon and love it if you do end up looking for an upgradeThanks. Ill try it!
Thanks!Yeah give it shot. I have the Adam’s foam cannon and love it if you do end up looking for an upgrade
Definetly order another foam cannon.Anyone have an opinion on whether the foam cannon that comes with this works well enough? I ordered the pressure washer, and wondering if I should plan on upgrading the foam cannon as well. Ues I can wait till it arrives and try it but figured I would ask.
Why are you making me spend money....dang it. Jk. I enjoy your posts and will start shopping from those you list here.Definetly order another foam cannon.
As mentioned, the foam quality generated by those supplied pressure washer foam cannons is thin and watery. I have been there and done this.
You don't have to spend crazy money either, plenty of affordable foam cannons on Amazon -
Amazon.com : foam cannon for pressure washer
Others to look at -
THE BOSS™ Foam Cannon - Griot's Garage (griotsgarage.com)
Adam's Premium Foam Cannon - Adam's Polishes (adamspolishes.com)
Search Results (autogeek.net)
The GT500 of foam cannons is the MTM PF22.2. I have been running these for a few years now and have never had a problem -
MTM Hydro PF22 Professional Foam Cannon (autogeek.net)
Thats the only thing that the PF22 does wrong, and certainly an advantage the competitors have over it. This is not something they can readily change without MTM redesigning the whole thing.The Griots Garage foam cannons work really well also. Keep in mind, the cannon only works well if you pair it with the correct restrictor. If you don’t you could end up with either a runny soap water or very fluffy soap bubbles that won’t stick to the car. Obsessed Garage had a good chart to determine what sized orifice you need based on which pressure washer you use.
Personally I use the PF22 and it works great. The only downside is the narrow neck for filling but it’s not that big of a deal.
In a technical sense, you are not overkill on this, it's generally the correct thing to do.I use my screw on funnel almost every day it seems and without a doubt, a necessary tool for this crazy subject all us OCD sufferers should have. :-) BUT, thanks for the tip on the tips <grin> I will be picking up a bag of those Real Soon Now.
Here's a question for The Man.
I have not been leaving the "cannons" in the bottles thinking the chemicals might oxidize the hardware or build up and reduce flow. I do leave the chemicals in the cannon bottles with a screw on cap but rinse the guns thoroughly after use. Is this overkill on my part, D?
