The rear end kicks out to the right sending the car nose left. Every single time it breaks loose. Its nothing in sport mode but with advance track off and just rolling into at at about 50mph in third it just breaks loose it swings out from under you within a second. I just have to back off and not over correct but there is no way to stay into it .Looking at your alignment sheet your left rear is .09 toe out and your right rear is .13 toe in
This will cause the car to go right on a launch or gear change.
Are you sure on that? with the thrust angle @ -.02 it shows the bar off to the left. And is one in and one out. Maybe I am not understanding the sheet correctly?.Looking at your alignment sheet your left rear is .09 toe out and your right rear is .13 toe in
Thanks for trying to help I appreciate it. IDK I never had a car with rear alignment but for front end to have toe in it has a - in front of the number and if not then it is positive. example - .5 left F -.5 right F equals - 1.0 total toe in. Im not sure on rear but wouldnt negative also have a - in front of the number? the way im reading it is my rear is positive .09 left and positive .13 right total .22 positive. To have negative lets say - .13 each side as per bmr specs of .13 in per side the sheet should read - .13 LR and -.13 RR for a total of -.26 rear toe in. I must be wrong though?.I hate it when they don't show the scale.
The way I read the sheet is left rear toe out right rear toe in.
The trust angle also looks like it would send the nose to the right on acceleration.
But I may be reading it wrong also.
So I was thinking toe in would be negative and have - in front of it. that would mean my front end is actually toed out .01 since its negative .01 correct?. And my rear are both positive which would be both sides toed in with left rear toed in .09 and right rear toed in more at 1.3 toe in making the car go left slightly in theory which it is doing also.Normal is TOE IN and is positive. CAMBER is normally negative.
This is why I wish they has shown the scaleSo I was thinking toe in would be negative and have - in front of it. that would mean my front end is actually toed out .01 since its negative .01 correct?. And my rear are both positive which would be both sides toed in with left rear toed in .09 and right rear toed in more at 1.3 toe in making the car go left slightly in theory which it is doing also.
If industry std is positive for toe in then my .09 left rear would be toed in .09. No ? going by the numbers. If it was toed out then it would be negative and read -.09. No?.Industry standard is positive for toe in.
If you look at the arrow on the left it is in the neg area. The right rear is in the positive area.
I'm going off the arrows since the green boxes are not labeledIf industry std is positive for toe in then my .09 left rear would be toed in .09. No ? going by the numbers. If it was toed out then it would be negative and read -.09. No?.
Im gonna try. if its not in the chassis or alignment it has to be the rear end not locking up both tires equally . Do you have a torsion rear pp car. Honestly the more im getting into this car and finding even with all the chassis mods mine has it just gets deeper. Adjustable toe links ok ordered. Find out even the pp car doesnt have the good bearing in the knuckle end so if you dont change that your only getting one end of the toe link upgraded really. The you got to veritical links which dont do much unless you change out the lower control arm bushing to the good bearings. Torsion rear no good for drag racing. Thats on top of the long list of steeda and bmr stuff already on the pp car. If you ask me this irs set up even in a pp car is a pain. Good for N/A twisty turns but for boosted cars ahhh its not the right piece for it really and needs a 100 band aids. Just my take.My car does the same thing, hit it in 2nd or 3rd and it pushes left rear end kicks out right. Unsure why but its been like that forever. Multiple people in groups on facebook have mentioned the same thing. If you find a solution I'm certainly going to follow you
