Popping Noise After GT Front Brake Conversion on S550 V6
Atticaz
Arizona
2017 Mustang V6
Hoping someone can help me out here.
Not sure is making this sound. Possibly the pad shifting? Could this be due to not enough grease on the back of the pads? It only happens after going forward and braking the first time, after going in reverse. Same thing when going in reverse and braking the first time, going forward. This is only happening on the passenger side. The mounting bolts are torqued to 85 ft-lbs. I also hit the pins with a scotch-brite pad and have a light coat of anti-seize on them, as they were a bit rough. I bought the brakes used.
[ame]
