Pony Projection Lights - Modification
MyMustangVault
Ghost Rhider
Cypress, TX
2015 LE WW #381
MOD OPTIONS:
1. Blink when turn signal is used.
2. Remain on as running lights.
Has anyone tried this? - or would know how to do it!? Seems like Option #1 would be easy by somehow going into the side mirror and splicing into a wire that goes to the turn signal light on the mirror.
Thoughts !?
willmkent
'Twas sure good see'in ya
Michigan
Will
2015 Ecoboost PP
Not a bad idea, I'm sure it's doable but it would require relays, I don't think it would be as easy as splicing a wire
terryrwood
Between Ga
2015 Mustang GT PP Roush S/C Manual
The only down side I could see is, unless they have solved the problem the image breaks up due to heat after a year or so. Had mine on my 13 warranty replaced. So running them all the time would probably speed the problem up.
