Please comment... Who has seen oil pump gear and crank sprocket failures?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by lucasmelobr, Oct 24, 2019.
  1. bauern
    bauern Well-Known Member
    First Name:
    Robert
    Vehicle(s):
    Ram 2500
    Aug 25, 2018
    somewhere else
    182
    116
    0   0   0
    sigintel likes this.
  2. olaosunt
    olaosunt Well-Known Member
    Vehicle(s):
    Jan 10, 2015
    Indiana
    3,253
    935
    Rating:
    100%
    1   0   0
    I had ordered too but cancelled mine before it shipped after learning no upgrade gears available .
    Not worth the risk.
    tevaburns likes this.
  3. sigintel
    sigintel Well-Known Member
    Vehicle(s):
    2018 GT
    Nov 24, 2015
    Republic of Texas
    1,719
    766
    Rating:
    100%
    1   0   0
    Nice. Thanks. Wonder how to set up the oil restrictors if I run predator block with stock GT heads...
    Going for poor mans road course S550 TT track rat.
  4. olaosunt
    Vehicle(s):
    Jan 10, 2015
    Indiana
    3,253
    935
    Rating:
    100%
    1   0   0
    With the GT 500 pump ?
    I would think you would stick to the GT restrictors.
    I think the only time you would swap the restrictor is with the GT 350 heads if you are using a GT pump . Then you have to use the GT restrictors .
  5. 80FoxCoupe
    80FoxCoupe Well-Known Member
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,603
    944
    Rating:
    100%
    5   0   0
    From what I understand, the oil restrictors in the cylinder head must match the oil pump used.
  6. olaosunt
    Vehicle(s):
    Jan 10, 2015
    Indiana
    3,253
    935
    Rating:
    100%
    1   0   0
    I think that depends on the heads .
    when I used a GT 350 pump with GT heads and GT restrictors I had no issues .
    I have had problem running the GT350 heads and GT 350 restrictors ) with the GT pump.
    The hole in the GT 350 restrictors is much smaller than in the GT restrictors so when use a lower pressure GT pump oil pressure is reduced drastically and causes me issues .
    confused yet.... lol
    :crazy:
  7. 80FoxCoupe
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,603
    944
    Rating:
    100%
    5   0   0
    What was the issue you had?
  8. olaosunt
    Vehicle(s):
    Jan 10, 2015
    Indiana
    3,253
    935
    Rating:
    100%
    1   0   0
    I had a top end noise and when we checked the pressure at the heads it was low .
  9. sigintel
    Vehicle(s):
    2018 GT
    Nov 24, 2015
    Republic of Texas
    1,719
    766
    Rating:
    100%
    1   0   0
    I used GT350 pump with GT heads (all OEM 2015) on my first motor. I ended up using GT stock oil restrictors even though using GT350 pump.
    Keep in mind, I was road coursing a stock 2015 block w a Whipple backed down to 9 psi by second season while spinning to 8000rpm. Went thru 3 sets timing chains and guides..lol...
    High rpm tears stuff up...
  10. olaosunt
    Vehicle(s):
    Jan 10, 2015
    Indiana
    3,253
    935
    Rating:
    100%
    1   0   0
Loading...
Share This Page
