Please comment... Who has seen oil pump gear and crank sprocket failures?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by lucasmelobr, Oct 24, 2019.
  1. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,289
    1,709
    Garage Profiles:
    You make a really good point regarding stress.
    I don’t honestly know that I could enjoy revving a blown engine to 8k on a semi regular basis, always wondering if THIS is going to be the one that kills the gears... is THIS going to be the one that costs me an engine?
    Of course, OPG isn’t the only thing that “could” go wrong but when it’s front and centre in your mind as a higher than average probability (vs rod failure for example) it would really take the fun factor out of it.
    Each to their own but I prefer to take measures where practical.
    Not sure that I’d do it at some of the prices being thrown around here though.
  2. DavidHuff
    DavidHuff Well-Known Member
    Vehicle(s):
    2017 5.0
    Jul 18, 2016
    Salem,OR
    1,327
    293
    Rating:
    100%
    3   0   0
    Did Ford use the same OPG/TG in the new 2020 Shelby GT500 as the ones in the 2015-2019 Mustang Gt?
  3. sigintel
    sigintel Well-Known Member
    Vehicle(s):
    2018 GT
    Nov 24, 2015
    Republic of Texas
    1,704
    762
    Rating:
    100%
    1   0   0
    TG forged 2018+ and GT500
  4. Roh92cp
    Roh92cp Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Will the 18 plus fluid dampers Fit on a 15-17?
  5. VRP
    VRP Boost Loading...
    First Name:
    Chase
    Vehicle(s):
    2015 GT Premium
    Apr 24, 2016
    Senoia, GA.
    612
    230
    Garage Profiles:
    They last a lot longer than most think, But I would definitely just do them now.
  6. roger1981
    roger1981 Member
    First Name:
    roger
    Vehicle(s):
    2017 mustang pp whipple
    Nov 23, 2019
    ma.
    do you think the gt350 pan is as good as say the moroso road race pan
  7. gixxersixxerman
    gixxersixxerman Well-Known Member
    First Name:
    Thomas
    Vehicle(s):
    2018 GT Premium PP1
    Jul 3, 2017
    Las Vegas
    721
    332
    Rating:
    100%
    1   0   0
    I think this sums up my feelings right here
    I’ve ordered mine and can do it myself. For me it’s a no brainer. I have the tools and the capability to do it so worth the 240$ on Black Friday. I can also afford a engine if it goes, but would rather spend that on other things.
    zero_chance and Burkey like this.
  8. 1MEAN18
    1MEAN18 Well-Known Member
    First Name:
    Vehicle(s):
    '18 GT
    May 5, 2019
    Where I stand
    624
    320
    Rating:
    100%
    6   0   0
    Just stay n/a and don't worry about it...that's a viable option that I'm gonna stick with. Even though I've seen a couple occasions where n/a E85 tuned '18's have broken opg's and the culprit then appears to have been bouncing off the rev limiter repeatedly. So being greedy trying to chase extra hp up top is where the stress is at, even on an n/a engine.
  9. epracmetcon
    epracmetcon Member
    First Name:
    Nick
    Vehicle(s):
    2016 GT M6
    May 16, 2019
    Rockford IL
    This is the way I looked at it. Chances are slim that they may fail, but there have been enough people that have broken them that it is a concern. Can I afford to replace the motor should it fail? Yes. Do I want to replace the engine because I did not replace a $300 set of gears? No. A day in the garage and $300 was cheap enough insurance and gives me a little peace of mind.
  10. bauern
    bauern Well-Known Member
    First Name:
    Robert
    Vehicle(s):
    Ram 2500
    Aug 25, 2018
    somewhere else
    182
    116
    0   0   0
    #25 bauern, Dec 11, 2019
    That's a transposition. The pan is more like $310. Holds more oil but since the windage tray is part of the pan, it's hard to see how it's baffled.
    The forged TG can be had for $21. + shipping from ANWB.
  11. roger1981
    roger1981 Member
    First Name:
    roger
    Vehicle(s):
    Nov 23, 2019
    ma.
    so even with the gt350 oil pan you were getting wear on the opg or you switched and the wear stopped?
  12. sigintel
    Vehicle(s):
    2018 GT
    Nov 24, 2015
    Republic of Texas
    1,704
    762
    Rating:
    100%
    1   0   0
    Would have to search the old posts for pics, but I think the issue was galling seen on stock opg and stock pump/pan. I switched to GT350 pan/pump/TSS opg.
    I believe crank deflection from Whipple combined w intermittent starve resulted in 0 margin from tolerance stackup thus OPG “self clearanced” the pump housing leaving burrs and galling as evidence. Repeated occurrences like this are brutal and expecting stock opg to survive long term is prolly not fair.
  13. sigintel
    Vehicle(s):
    2018 GT
    Nov 24, 2015
    Republic of Texas
    1,704
    762
    Rating:
    100%
    1   0   0
    GT350 pan is proven by Ford on track and $150 thru grassroots support for 5.0 track use. If you are at hpde or track days and dont have a local Ford contact or someone that can get you a pan, just PM.
  14. ninjacoupe
    ninjacoupe Well-Known Member
    First Name:
    Sam
    Vehicle(s):
    2018 Mustang gt
    Aug 10, 2018
    Patchogue NY
    72
    2019 Hellion twin turbo at 825rwhp A10 auto approximately 5k hard miles. I run it in track mode not drag for the easier hit on the tires on the up shifts but it is very aggressive on the down shifts. I was minding my business next to a Porsche who was also minding his own business. As it shifted into what I believe was 6th I got a warning on the dash that said oil pressure lower than expected and a limp mode. I saw it was still making about 40 psi and called for a tow home. I got lucky. Oil/filter are clean. Cams look good. There are two other twin turbo Hellion cars and a whipple gen 3 in the group who all had them done at the time of the install. I’m the only one who didn’t.
    02F0CB0E-1069-42ED-898B-08F470577B87.jpeg 6F8AECB1-968A-4E38-B8F7-FE266A226388.jpeg C542D794-D3DD-48E4-9083-AF519A5C2E39.jpeg
  15. Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Mine happened in 4th gear manual at 6k, I shut it down and towed it. I flushed the motor several times changed OPG and started perfect and ran for about a minute before rod knock started and ended sounding like a freight train. She was done. What RPM did your fail at?
    Here was my startup after I replaced OPG, only thing missing was me yelling out Faaaaaaak!! in the end.
Loading...
Share This Page
