Plastic flap (shield) blocking oil filter canister on 2021 GT500
dbtgt
Oklahoma
David
2021 GT500
Has anyone else found this plastic "flap" blocking easy access to the oil filter?
It's really inconvenient and a PITA to deal with.
Does anyone know its purpose? Possibly a shield against an oil leak?
WD Pro
United Kingdom
Lime GT
In GT land, Ford Performance call it a splash shield :
WD :like:
jacknifetoaswan
Charleston, SC
Maybe I'm not understanding, but why is that inconvenient? Are you trying to access the oil filter from the wheel well? Why not just get at it from under the car, like the good Lord intended?
JR
dbtgt
dbtgt
Oklahoma
David
2021 GT500
JR
Because I am using @pilotgore's oil filter guide. It makes for a much cleaner filter change.
pilotgore
US
A bunch
Interesting. . . Can it be easily moved with the bottom resting on the sway bar, or is it hard plastic? I have a TON of filter guides out there for the gt500 and just learned of this flap yesterday on a different forum. Need to borrow a dremel? :)
WD Pro
United Kingdom
Lime GT
I seem to remember mine being quite flexible, but Iā€™m not sure I would flex it enough to get it up onto the sway bar.
Note though, my ā€˜flapā€™ is much longer then that shown in the Ford Performance diagram and I have a 20 euro GT, not a 500 :like:
WD :like:
dbtgt
dbtgt
Oklahoma
David
2021 GT500
It is pretty hard plastic. It is "movable" but not very flexible. I tried to bend it enough to get it above the sway bar but felt like it might break before getting it where it needed to be. I'm not keen on modifying OEM items on the car but seems like the only good option. I was able to get the oil filter guide In and locked in place, it just wasn't very easy or straightforward like it is on the GT350. Not much room for your hands to orient, twist, and lock the guide into place.
Is it possible that this flap is a "late" 2021 addition made by Ford and therefore not found on earlier GT500 cars? My car is a November 2021 build.
dbtgt
dbtgt
Oklahoma
David
2021 GT500
WD :like:
My flap is the longer version also.
Interesting that it shows up on your GT, my GT500, but not the GT350...
pilotgore
US
A bunch
Bummerā€¦..
If the oil filter guide becomes a nuisance to use, Iā€™d be more than happy to give you a refund.
dbtgt
dbtgt
Oklahoma
David
2021 GT500
Bummerā€¦..
No way!
I love the guide. It is perfect for the job. I was just curious about the "shield" as I hadn't seen it mentioned anywhere before and was surprised to run into it.
I will continue to use the guide, and now I know how to get it on with the shield in the way.
You have a great product!:thumbsup:
pilotgore
US
A bunch
No way!
Awesome, glad to hear! I appreciate that!
PP2
NC
Evan
2021 GT500
David, I've done a few oil changes on my GT500 with Pilotgore's filter funnel and you can bend that flap up to the sway bar without it breaking. It's rigid, but it will make up and will look like nothing was ever done after you move it back.
dbtgt
dbtgt
Oklahoma
David
2021 GT500
David: I have a '20 and it has the flap so it's not new.
Thanks for clarifying this!
Good to know it won't break!
That will make the job much easier.
  • Like
Reactions: PP2
