IamCDNJosh
- Apr 19, 2020
- Lake Oswego, OR
- Josh
- 2015 Mustang GT PP, 2015 F150 3.5EB FX4
So I realize that all of these points may have been individually covered in other posts, but I wanted to have others with experience poke holes in my plan here for my 2015 GT PP1.
First I'm not really interested in selling this car, it was something I bought after leaving an unhappy marriage and I didn't have anyone to tell me "no". This car represents not only my freedom but my decision to be happy in my life. With that out of the way, I've been VERY interested in the approach that Ford has taken with the new Mach 1 in installing the Tremec 3160 as well as having a differential cooler. Getting a Mach 1 really isn't an option, I could afford it but I'm not going to pay 30+K for a car that's similar to what I have now. Lastly, I tend to avoid the aftermarket when at all possible, I'd call my style OEM+ which is why I've stuck largely with FP, Roush & RTR for both my GT and F150.
My car is primarily a GT car, I'm not trying to keep the miles down plus I want to use it for a few track days per year. For power mods I'm not going to add anything additional, I've got a Roush PP1 (Intake & ECU flash that is octane adaptive for any of those rural gas stations that may not have premium) along with the FP Sport exhaust with the GT350 rear valance (more on that in a bit). For suspension I've kept my PP1 suspension stock other than getting the FP X-springs which gives me all the components from the Street Handling Pack. No plans on FI as the compression & cooling is not ideal for track use, that and with power at that level I'd want some kind of DCT anyways.
So that being said, I'm looking to do a drivetrain overhaul that will give me a Tremec 3160 like experience as well as not having to worry about my differential temps at the track. So that being said, below are my plans and I'd like to have some input here from those that have experience. As I have a second vehicle to drive (F150) downtime is not a concern as well as I can do most of the work myself as I've been wrenching on cars since I was a teenager (almost 40 now)
1. Transmission Rebuild - We all know the MT-82 has some serious design flaws, while my transmission hasn't failed it grinds while its cold as well as being extremely notchy. I've toyed with going for a 3160 but it sounds like I'd have to load some kind of custom tune to make it work so this may be a non starter as I'm not interested in an e-mail tune. The other Tremec options are off the table but the ratio's aren't ideal for an N/A setup like mine with a 3.73 rear. So that brings me to an aftermarket solution. I'm looking at removing my working MT-82 and sending it to Calimer Performance to do a Stage 1 rebuild. Remember here I'm likely only going to be pushing 470ish to the crank. The clutch line would be replaced by the FP upgraded version M-7512-B. Flywheel would be replaced by the Ford performance version M-6375-M50 and would love suggestions for a clutch (please keep in mind my power output, I don't need some crazy clutch rated for 1000hp).
2. Shifter - This is quick, but I do have a Ford Performance unit sitting in my garage, I haven't installed it because I haven't quite decided which way I'm going.
3. Remote Mount Issue - Now I've had the infamous 3rd gear lockout, to which I ordered the whiteline transmission bushing and sawed off the middle section to reduce NVH in the vehicle as this is a drivers car my new wife will ride in, not a racecar. Beyond that I may have to go to the aftermarket here as there isn't a factory option and get a blowfish bracket as this will also be compatible with the FP short shifter. Sorry not interested in a Barton/Steeda unit.
4. Differential - I've seen some of the workarounds for trying to have extended tracktimes with the differential but they all come across as bandaids. Now I know that there is a unit from FTB which seems to be perfectly capable. Again I want to go OEM here if I can which brings me to what I'd really like to do to address this issue.
I'm looking at purchasing the GT350 rear closeout panel as the GT350 valence on my car is the OEM piece. Closeout Panel
I would also like to purchase the GT350 rear differential cooler to go along with it. GT350 Cooler
I realize that this is more expensive than the FTB cooler, but again I'm trying to stay OEM wherever possible and I'm going to be keeping this car in my collection for a long time.
5. Transmission Cooling - For transmission cooling at track days I was looking to install the FP air scoop and it will be only installed for track days and otherwise removed when street driven (my car will be trailered to the track). FP Transmission Air Scoop
So that's it, sorry for the long winded post but like I said I'm wanting to correct the sins of the S550 GT without having to purchase a new Mach1. Any thoughts, suggestions or debate would be appreciated. Budget isn't much of an issue, so again I'm not interested in cheap band-aids but rather I want to do this right without adding NVH or negatively affecting drivability.
