Pirelli Sidewall Bubbles?
NCFlyer
Central NC
Tom
2020 GT350 HE
I dropped off one of my PP rear tires at a local Firestone shop to remove a small nail in the center tread. The tire was holding pressure (32 psi) with no other obvious issues. The shop called and asked if I drove the tire flat, which I hadn't, when I asked why they told me the inner sidewall has "belt damage."
The pics show what I found when I picked up the tire. I'm trying to figure out how the heck that happened! Four blisters, evenly spaced apart and 180 degrees apart. It was fine at 8am and blowing up by 2. The manager refused to even consider it was caused by the shop. Anyone else have bubbles show up?
No warranty either, I bought these two years ago from a friend who upgraded his PP GT. He had ~1K miles on them and I put another 2K on them.
Guess it's time to start shopping for those michelin pilot super sports.
CB
Near Pittsburgh, PA
2016 GT, Black, PP
Maybe the air inside the tire got between the rubber layers from around the nail hole.
shawn3210
So. Cal.
16 PP Triple yellow
Same thing happened to mine, super small bubble though. Luckily I had brought warranty at america's/discount tire right when I got the car and got a new tire under warranty. If you have the tire shop call pirelli warranty line they sometime can give you a proration. But might be out of luck since you didn't buy them from a retailer nor did it come on the car new.
VinnAY
Kansas City
18 Camaro 1SS/1LE
Potholes...doesn't take much at all to rupture a sidewall, less than it takes to bend a wheel, and I've done both. Requires replacement of tire.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
That's pretty common on those tires after pot hole interactions lol. Look into a tire with a harder sidewall.
Jetset335
Atlanta
Bill
2019 GT350
I had this happen at the dealer when the rear tires were removed to fix small leaks. Ford replaced both rear PP tires for free. I had before & after pics that look just like yours. Only 2 bubbles, 5k miles on the tires.
wildcatgoal
@sirboom_photography
TBD
Man... the people who have had problems with these tires. I thought they were fine. I never had an issue. I guess I'm lucky for once. But good lordy WTF happened to those!
NvrFinished
So Cal
2016 DIB GTPP
I put in quite a few years running a tire store quite a while ago. Many times what happens with tires that are brought in for repair or slow leaks is damage to the sidewalls from excess heat. People will drive on the tires not knowing they are getting low on air. The low air pressure causes a lot of friction due to lower rolling resistance. This heat causes the inner bladder along the sidewall to break down. The bladder is what makes the tire tubeless. The air will find it's way through the bladder and shows up as sidewall bubbles since they are the softest part of a tire. Cycling back and forth from low air pressure to normal when milking a slow leak will weaken a sidewall as well.
Of course with tire pressure monitoring systems in most new cars these days many of these problems can be avoided. I'm not saying this is what the OP did, but it's the reason for a lot of bad sidewalls.
LG23
'16 GT
Was randomly told by some friends to look out for this on these tires specifically, guess they weren't just making it up.
saleen405
Northeast
Scott
2015 Ruby Red GT PP
These tires are garbage and glad to rid them from my car.
