Pinion bearing losing pre-load. Only after making a couple passes..... Strange. 3rd time.
gimmie11s
SoCal
Murica!
Interesting thread. Subbing for the source of info.
308 Cal. Bullitt
Midwestern-former Left coast
Dee
'22 GT500 + other 2/4/& 6 wheeled trash barges
A crush sleeve 'eliminator'
is more of a 'replacer', if anything.
But yeah.. To ea his own verbage.
Crush sleeves on heavy cars over 35/3600lbs,
or running quicker that about a
~1.40 -60ft, on a drag strip..
(Especially w/traction via good tires or decent track prep)..
Is likely gonna cause heartache.
& this problem.
We all hav our own parameters based on our own experiences. Drag race cars w/pwr & or wt#, need solid spacers between both pinion bearings. Soft materials will fail. I.E. crush sleeve
Just for the record. If anyone decides to do LOW DRAG, angular contact ball bearings-
(vs a tune or other warranty voiding power adders),
on either the 'LOAD' side rear bearing only,
(a poor mans method)
or both pinion bearings đź‘Ť.
U must.. MUST.. Use a
'solid pinion spacer'. You cannot preload an angular contact ball bearing.
Ceramic or steel balls.
A crush sleeve will negate (& damage) any gains on an angular contact ball bearing, & it will qwikly destroy the bearings with the additional Axial load force on them. From torquing dwn the driveshaft pinion flange, like a crush sleeve normally endures.
Literally, a pce of 4130 Condition N tubing, works for a crush sleeve replacement, as a solid pinion spacer.
On nearly any/all rear ends.
Size specific obviously.
Chamfers often necessary.
Material thickness on a mchined sleeve should be at ~ .100" minimum wall, material, with tensile strength ~68,000+ psi. Preferably closer to ~85k+ psi tensile.
(not yield)
The thicker it is, the softer the material can be, obviously.
Just want to avoid the collapse of the spacer, by even ~.0005"
WD Pro
United Kingdom
Lime GT
I'm getting ready to change mine also, and have also been told about the importance of a friction modifier.
Based on my experience with a low mileage track loc mounted in Steeda diff and subframe bushes, yes, that was an absolute necessity :like:
WD :like:
