honeybadger
Just don't care
do you have pics of your fronts?
Those look more than fine for at least another day. Good chance they'll start to chunk on day 4, but I'd still run them. If the tire hasn't chunked yet, you have least 1 more day. You can run them once they start to chunk (albeit very small chunks), but you'll only get another couple of sessions after that.Here are pictures of my front and rear SC2 tires after two track days. One @ NJMP Thunderbolt and one @ NJMP Lightning. I was thinking the fronts are done but rears can have another one or two track days.
I have -2.5 front and -2 rear camber, with plates and probably will go for -3 next track day. I can also confirm that 305/30/19 98Y has less tread compared to the 305/30/19 102Y but at Tire Rack it is like 60$ more per tire - 460 $ vs 399 $.
I agree with firestarter2, would hate to trow away good tires. Advise welcome - thanks
Front SC2Rear SC2View attachment 305213
I find your pad life interesting. I've run Mid-Ohio and Grattan in my R. I consistently get ~3 hours out of a set of front brake pads, but the tires are doing pretty well. ~2500 easy street miles and 6 track days, but two days were wet so minimal tire wear. I think I can get another day or two out of the fronts, two more days on the rears. Grattan is hard on the LF tire. All in, I figure I am getting about 10-12 hours of dry-track run time for a set of tires.Ya, there are a lot of factors. My last day with pics above was waterford hills which is an older track with concrete in corners (is getttjf all new asphalt now) which is why mine shredded. This was actually my fifth event, but only did 3 of 5 sessions and had two half days in the rain so really count as four full aggressive 5 session days probably.
I mentioned my driving style bc there is another R in a middle run group which similar days and much better tires but his lap times are way way more conservative. My front brake pads will probably be shot after 6 days for example, his looked brand new. Driving style is a big factor.
Agree 100%; you can run them until the outer circumferential groove is totally gone and the outer shoulder grooves are totally gone, and you still have another day to go at least. I would put another weekend on those tires. Worst case I'd be diligent about a gentle warm-up lap; I have noticed they take longer and longer to "come in" as they wear.Those look more than fine for at least another day. Good chance they'll start to chunk on day 4, but I'd still run them. If the tire hasn't chunked yet, you have least 1 more day. You can run them once they start to chunk (albeit very small chunks), but you'll only get another couple of sessions after that.
Fortunately Cup2s just progressively lose grip, they don't get super greasy (at least in my experience).
TILAgree 100%; you can run them until the outer circumferential groove is totally gone and the outer shoulder grooves are totally gone, and you still have another day to go at least. I would put another weekend on those tires. Worst case I'd be diligent about a gentle warm-up lap; I have noticed they take longer and longer to "come in" as they wear.
Here are my fronts my two best.
Two full days left on those no problem. Maybe 3 IF you rotate/swap the fronts. Driver side outside is going to wear much faster as you are showing on clockwise tracks.Here are my fronts my two best.
You'll be fine.Based on the pictures and replies already posted in this thread, I think I know the answer to my question, but I'll ask anyway. See pic of driver's side front tire below. Safe to say I'm good for one or two more track days? (I'm in the intermediate run group and will be tracked at Autobahn in Joliet, IL)
You’re correct… those look brand new and you’ll have zero issues getting AT LEAST 2 days out of them in the intermediate run group.Based on the pictures and replies already posted in this thread, I think I know the answer to my question, but I'll ask anyway. See pic of driver's side front tire below. Safe to say I'm good for one or two more track days? (I'm in the intermediate run group and will be tracked at Autobahn in Joliet, IL)
Depends on the track and your abilities, but at least a few days.What does anybody think of the track days left in these? They are cheap and local to me.
