Per Ford (officially) the 2011-2019 F150/Mustang 5.0 “Typewriter Tick” is a normal characteristic
Discussion in 'Issues, Repairs, Warranty, TSB, Recalls' started by Cobra Jet, Feb 5, 2019.
  1. Mazman
    Mazman Well-Known Member
    Vehicle(s):
    2018 PP1 Mustang GT
    Aug 15, 2017
    Sweden
    662
    272
    Garage Profiles:
    #101 Mazman, Feb 12, 2019
    Yesterday I was officially given the F U finger from Ford and the dealer. Info coming from a call yesterday from the Marketing Manager at the dealer
    On my second motor I am having the typewriter tick and the 2K slap. The car is at the dealer at the moment and they sent me a video where there is chatter/rattle at lift off during idle.
    So the car has three different sounds/slaps/ticks/call it whatever
    - On my second motor to rectify the 2K slap my injectors have been swapped and my manifold has been swapped....
    I have mainly pushed for the 2K slap while in gear, I have also mentioned that I have the typewriter tick when the car is cold.
    Ford released this SSM message now both Ford Sweden and the dealer tells me they won't do anything with the car as the message has been released by Ford.
    - Mind you the only Ford technician taking these type of decisions have not even heard or seen the car. Only basing the info from what the dealer have told him.
    They are all referring to that the typewriter tick is the same as the 2K slap and the sound at lift of during idle. So they will take no further action... I was telling them how can you interpret the message which states that after an oil change some 5.0L engines at 150F and above and RPM up to 1700 during idle can give a typewriter tick with a 2K slapping sound while in gear driving. They still say it is the same....
    To add to this
    I have had my front door and front fender painted as they had nudged (this I saw day 1)
    My trunk lid has nudged the rear fender and both parts needs to be painted
    My window trimmings are not glued properly
    I have dust under the paint
    I have imperfections in the sheet metal that shows through the paint and clear coat
    I have told them I want a similar car that would cost me the same or I want Ford to buy they car back.
    They cannot and will not offer me either
    Honestly WTF is this....
    YoloBathsalts likes this.
  2. GT Pony
    GT Pony Well-Known Member
    Vehicle(s):
    Mar 13, 2015
    Pacific NW
    5,820
    1,381
    0   0   0
    #102 GT Pony, Feb 12, 2019
    Ford's new SSM is talking about the BBQ tick, which they cal the "typewriter tick". They are not addressing the "2000 RPM rattle".
    Are you saying the oil pump is the cause of the BBQ tick? I doubt it since the tick is low and at the rear of the engine, just like Ford said in their SSM. The oil pump is at the front of the engine.
  3. GT Pony
    Vehicle(s):
    Mar 13, 2015
    Pacific NW
    5,820
    1,381
    0   0   0
    But can dealerships distinguish the difference? I doubt many can, so people that have any kind of ticking are now just going to be told it's "normal" because that's what the SSM says.
  4. GT Pony
    Vehicle(s):
    Mar 13, 2015
    Pacific NW
    5,820
    1,381
    0   0   0
    Yep ... use a good full synthetic 5W-30 with a good dose of Moly (anti-friction additive) in the formulation.
  5. GT Pony
    Vehicle(s):
    Mar 13, 2015
    Pacific NW
    5,820
    1,381
    0   0   0
    If it's caused by oil cavitation in the journal bearings, then why don't they all do it? Can't be that much difference in bearings to make some tick while others are quiet, while all use the same 5W-20 Motorcraft oil.
    If you research oil cavitation, it says thicker oil is more likely to cavitate. So the ticking should be worse at a cold start, or with thicker oil, but seems the opposite is true. It also says that oil cavitation can do lots of damage (surface errosion of metals).
    I still think it's caused by excessive rod side clearance and/or excessive crankshaft end play clearance.
    Has anyone tried sitting on a steep hill or run the car with the front end up on ramps to see if the BBQ tick changes when the crankshaft is not horizontal? In other words, when gravity is making the crankshaft ride hard on the thrust bearing? If it's excessive end play that test may cause the tick to change or disappear.
    HoosierDaddy likes this.
  6. jake_zx2
    jake_zx2 Well-Known Member
    Vehicle(s):
    Kona Blue 2018 GT
    Jun 19, 2016
    1,177
    476
    Garage Profiles:
    "Only referenced the TSB when a customer complained"
    So, what you're saying is there was a TSB for it
    So, in other words, Ford actually said there was something wrong with the car.
    Thank you
  7. jake_zx2
    Vehicle(s):
    Kona Blue 2018 GT
    Jun 19, 2016
    1,177
    476
    Garage Profiles:
    From what I've seen, the actual problematic noises (piston slap) have been at ALL RPMs, not just idle-1700. If the noise exists above 1700RPM, then it does not fall in line with the noise described in the TSB and should be taken care of by a dealership
  8. CEHollier
    CEHollier Well-Known Member
    First Name:
    Charles
    Vehicle(s):
    2015 GT Premium Magnetic
    Sep 6, 2015
    Prairieville, La.
    1,259
    466
    Garage Profiles:
    Damn. That sounds bad.
  9. MasterCylinder
    MasterCylinder Well-Known Member
    Vehicle(s):
    17 GT
    Jan 20, 2017
    Fort Worth, Tx
    278
    57
    0   0   0
    Also slightly sounds like an exhaust leak.
  10. 18P51GT
    18P51GT Well-Known Member
    First Name:
    Travis
    Vehicle(s):
    Oct 17, 2018
    WA
    70
    Garage Profiles:
    No. Mine has tolerance issues between the piston and cylinder wall leading to oil consumption and metal in the oil causing the clatter.
  11. NastyPumpkin
    NastyPumpkin Well-Known Member
    Vehicle(s):
    2018 Mustang GT PP1 Orange Fury (JLT-CAI - Full E85 tune, Long Tube Headers cat/delete, Roush X-Pipe, WELD wheels, M/T tires, Ford Racing half shafts, complete STEEDA stop the hop kit)
    Oct 13, 2018
    Michigan
    56
    30
    0   0   0
    Typewriter noise
    “Oil Cavitation” That is what I was told by Ford 5.0 Powertrain Engineering. They have been testing different types of bearings, I was told. Also Oil Cavitation was the cause in the Diesel engine, that went on for 11 years. They solved that one by redesigning the oil pump and moving it. This is what I was told by Ford. That’s all I got!
    OhNoA5.0 likes this.
  12. OhNoA5.0
    OhNoA5.0 Member
    First Name:
    Lee
    Vehicle(s):
    2018 PP1 Orange Fury GT
    Jan 15, 2019
    Georgia
    Actually oil like the 5w-20 is thinner when cold and thicker when hot. The 5 is cold viscosity and the 20 is warm viscosity.
  13. Zitrosounds
    Zitrosounds Well-Known Member
    First Name:
    Harold
    Vehicle(s):
    Oct 20, 2015
    Madison, AL
    3,250
    2,020
    0   0   0
    I owned 2 Coyote mustangs. Both had the tick. Both cars ran road courses. Both cars had no engine mechanical issues. The 2012 had 75k miles N/A full bolt on's and the 15 had 20k. Now the transmission (MT82) however!!! caca.
    Colleton and NorthernBeast like this.
  14. NorthernBeast
    NorthernBeast Well-Known Member
    Vehicle(s):
    Black 18’ GT with PP1 + Active Exhaust + Mag
    Jan 21, 2018
    Canada
    57
    30
    Garage Profiles:
    You fully realize that the Ford statement states 2011-2019 5.0 V8's meaning your hysterical response is completely unfounded. There's nothing wrong with the 2018+ motor that isn't also wrong with the 2011-2017 versions.
    There are far more of these that exhibit zero tick than there are that do exhibit the noise. Social media has brought this to our attention more than before but there's nothing 'wrong' with the 2018+ 5.0. It just won 10 best engines in the world again for 2018 LOL
    smoke_wagon_6g and jake_zx2 like this.
  15. 18P51GT
    First Name:
    Travis
    Vehicle(s):
    Oct 17, 2018
    WA
    70
    Garage Profiles:
    It might be a little different for some of us when it becomes an actual mechanical problem and throws out misfire codes.
    Overall, I believe that these engine are outstanding. However, one still needs to look at it in a mass production point of view. Not all of them would ever be 100%. Not even from an aerospace machinist perspective. Even so, I still have faith. It’s a beast of a motor. I can’t wait to get mine back again. Just in time for spring to hit. It’s an awesome ride.
    samanosuke47 and OhNoA5.0 like this.
  16. Schwerin
    Schwerin Well-Known Member
    Vehicle(s):
    Future Mustang Owner.
    Jan 31, 2018
    Philly
    178
    Wut.
    Watch that video. Now pour one of those at room temp and tell me that it somehow is "thicker" than the examples in the video.
    The oil gets thinner when hot, but due to additives it's viscosity goes up.
  17. NorthernBeast
    Vehicle(s):
    Jan 21, 2018
    Canada
    57
    30
    Garage Profiles:
    LMAO common man this video is so off. The oil that people are using is 5W-30 vs 5W-20
  18. OhNoA5.0
    OhNoA5.0 Member
    First Name:
    Lee
    Vehicle(s):
    Jan 15, 2019
    Georgia
    Hey please research this more. I wasnt try to come off as your wrong and im right. I just see some stuff posted that can point people in the wrong direction. In 5w (which stands for winter) 20 oil, the 5 is thinner when it is cold than at normal operating temperature which is the 20. The viscosity goes up (thicker) as it heats up. I can link you several pages that further explain this is you like. Actually here is just one link to read up on https://www.motorstate.com/oilviscosity.htm
    BlownGP and samanosuke47 like this.
  19. Schwerin
    Vehicle(s):
    Jan 31, 2018
    Philly
    178
  20. Schwerin
    Vehicle(s):
    Jan 31, 2018
    Philly
    178
    #120 Schwerin, Feb 12, 2019
    But that is not what the person you quoted is talking about. He is talking about the cold oil vs warm oil. I don't care about all the technical terms. What he is clearly saying is that when cold the less viscus oil is what should cause cavitation as it is THICKER/Denser/oozier/what ever you want to call it. Thick, like a milk shake.
    This is why I hate oil conversations people get hung up on terms instead of trying to get the meaning of what is said.
    Either way I believe his point is when temperatures are too cold (during wintertime, for example), the viscosity may be too high to enable proper oil flow in the suction line and into the pump. Other causes of high oil viscosity can lead to the same problem. Perhaps what should really be run is a 5w30 or 40 as it seems to show up when warm the 5w is likely fine, the other weight should be changed.
    I'd like to hear more from the Australian cars that get 5w30 recommended weight. See how many of those have ticks. My old 32v 4.6 would tick like no tomorrow until I put a 30 or 40 in it. If I ever put 20 in it, it was SUPER noisy almost to the point of not being happy.
    I'd also like to know what changed to make Ford now say that 50 is no longer needed for track use in the GT. If anything tolerances seem to be looser now.
Loading...
Share This Page
