Pair of 15" Baer Brakes Eradispeed-Plus 2-Piece Front Brake Rotors
Status
Not open for further replies.
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
A large variety of Mustangs across all generations
Pair of 15" Baer Brakes Eradispeed-Plus 2-Piece Front Brake Rotors for all 2015, 2016 and 2017 GT Mustangs equipped with the Performance Pack.
You now have the opportunity to install a truly race-inspired upgrade to your 2015-2017 Performance Pack GT Mustang that is typically only found in high-dollar big brake kits or on high-end exotic cars!
This pair of 15” Baer Brakes Eradispeed-Plus 2-Piece Front Brake Rotors (P/N: 2261042) is a direct replacement for all 2015-2017 GT Mustangs that are equipped with the optional Performance Pack. They are designed to work seamlessly with the factory Brembo 6-Piston caliper and brake pads found on the Performance Package GT models. These 15" rotors feature a drilled and slotted design for added braking performance along with directional vanes. The 2-Piece construction utilizes an anodized black 6061-T6 aluminum center hat that is bolted to the rotor ring, allowing for a major decrease in rotational mass.
[ame="[MEDIA=youtube]TX3p1gFu7k4[/MEDIA]"]
Features and Benefits:
- Compatible with the OE 6-Piston Brembo Caliper
- Can be used with your Existing Stock Brake Pads
- 15” Diameter with a Drilled and Slotted Rotor Ring
- Anodized Black 6061-T6 Aluminum Center Hat
- 2-Piece Design with Directional Vanes
- Zinc Plated for Corrosion Resistance
- 10 lbs. Lighter then Factory Rotors (Each)
- Sold as a Pair
*These rotors will NOT fit the 2015-2017 GT350, GT350R, Base Model GT, Performance Pack Ecoboost, Base Model EcoBoost or V6 Mustang.
Manufacturer Part Number: 2261042
We all know the thrill that comes with upgrading your Mustang’s power and performance so it’s the loudest and fastest on the block. Who doesn’t like that classic engine rev and the thrill of racing down the open road? While this excitement makes for the ultimate driving experience, it’s important that you stay safe behind the wheel. When upgrading your engine, it’s vital to ensure that your brakes have the power to stop it.
Order this pair of 15" Baer Brakes Eradispeed-Plus 2-Piece Front Brake Rotors for your 2015, 2016 or 2017 Mustang GT that is equipped with the Performance Pack from CJ Pony Parts today!
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
How is the noise and squealing with these rotors? Would you recommend a specific set of pads to optimize these rotors? If so, how is the noise with those?
CJ Pony Parts
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
Bill has had these on his car for 6 months using the factory pads and has even driven his car across the country and back and attended a track day with them. He has not reported any squealing or noise and he has nothing but good things to say about the performance based on that combination.
Status
