Grimmer
The parking lights should be on both the unused connector and the turn signal connector. In the factory fixture the now unused connector's bulb has a single filament for parking lights only. The turn signal bulb is dual filament, one for parking/marker (low) and the other for the brighter turn signal (high).
If you are not getting white from your Arrows when the parking lights are on then there is a problem with them. Odd that they are both screwed up though. A quick test would be to switch the headlight dash selector to park or on (with the ignition/car completely off). They should then be white. Turn on the hazards and they should both start sequencing amber. Turn the hazards off and they should both fade back to white. If this is not happening, then tell OPT7 and you should get replacements.
Also keep in mind that the front turn signal fixture's marker lights are not on an independent circuit. The rear side markers and rear tail lights will also be on when FORScan or the dash switch has activated the parking light circuit. This can also help indicate if the FORScan change has added the parking circuit as DRL's.
