Opinions Wanted Mickey Thompson Drag Radial R 275/40-17
TEXAS HEAT
TEXAS
2019 Mustang GT PP1 A10
I'm looking for input regarding the MT Drag Radial R in 275/40-17 for naturally aspirated applications. Specifically on an 18-19 A10 PP1 equipped GT. First time at track bone stock I ran a 12.36@117mph with pretty bad wheel hop on the 1-2 shift. I've since added BMR CB005, Steeda alignment kit made for the CB005 and BMR's subframe bushing inserts. The bushing inserts are coming out due to what I feel is extreme gear noise at cruising speeds. I'm adding the CB762 along with BMR's poly vertical links. I'm hoping with the right tire I can eliminate my wheel hop issues and get the car well into the mid-high 11's with stock tune. Only mods being suspension and tires. I would like to hear from anyone with experience with this specific size MT offering versus the 305mm 28" tire. Pro's, cons and personal experience welcomed. Thanks!
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
i think it depends on power output. i prefer the 28" tire. i think 26 is too short unless you a 3.15
brucelinc
MN
Bruce
2018 Mustang GT premium A10 (SOLD)
I have MT ET street R tires in 275/40-17. They stick like glue. I had hellacious wheel hop with street tires on the 1-2 shift even though I had the CB005 kit. The Mickeys solved the wheel hop 100%.
My car is stock and the best time so far is 11.89 with the Mickeys. The car is an A10 with 3.55 gear. I was a bit worried about breaking an axle since the car hooked so well. For that reason, I didn't launch it super aggressively. I have now upgraded the driver's side axle so I think I can improve my times with a harder launch.
I prefer the 26 inch tire because it gives me an effective gear of around 3.70. If I was planning on substantial power increases, I may have gone to a 28 inch. However, with a little heat in the 275 tires, they hook incredibly well.
TEXAS HEAT
TEXAS
Thanks for the input, what tire pressures have you found to work best in them?
brucelinc
MN
Bruce
That is a good question. I didn't get the tires until the last 2 events of the season and since it was so busy, I only got in a total of 6 or 7 runs with them. That didn't really give me the opportunity to experiment much. I think they recommend around 16-18 PSI. I started with 22 PSI and they hooked so well that I didn't lower them. I was in the 11s on every run and was so happy to not have wheel hop, that I just left them alone. When I go back to the track in May, I will find the sweet spot for pressure and the sweet spot for launch procedure.
TEXAS HEAT
TEXAS
What is your rear wheel width? 9" or 10"?
brucelinc
MN
Bruce
17 X 9.
OU81
Walker, La
Gary
2019 Mustang GT PP1
I have the same set up at above on my stock 19 a10. The car has 3.55's & I opted for the budget friendly 17x9 Bullitts with 275/40 MT dr's. I have only been out once on them but they work great. It ran a 12.08 at 117(not drag mode equipped) in +1000 da. I am happy so far with them
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
60ft time???
OU81
Walker, La
Gary
2019 Mustang GT PP1
I'm pretty well done with the track til next fall but I will try that when I get back again.
18 Smoke
Columbus, OH
18 Mustang GT PP1 400a
We took my brothers 18 A10 to the track for the first time on my 305/45 17 SS. It is bone stock and went 11.89@117. He then found a killer deal on some 19x10 wheels with 285/35 19 SS on them. Next time out 11.75@119. It has 3.55 gears and is still bone stock. We were running both @19psi. I’m not sure of his 60ft, but I know it was better on the shorter tire
brucelinc
MN
Bruce
I have seen many cases at my tracks where guys with stock engines or even minor mods go slower with a 28 inch tire. There is a video around here somewhere from American Muscle where they did comparisons of stock, 93 tuned, E85 tuned, and DRs. They used a 28 inch DR and ran slower than on street tires when stock.
