GT Pony
- Mar 13, 2015
- Pacific NW
- 2015 GT Premium, Black w/Saddle, 19s, NAV
The ticking seems to be caused by mechanical parts hitting each other. One theory was excessive rod side clearance was causing it. Simone had a ticking Coyote, and had an independent shop remove the oil pan and checked the rod side clearance, and found them all to be over the maximum specified clearance. Then some other independent engine inspector came and said the rod side clearance was good ... so I found that strange.so it can not be a mechanical problem then. or can you fix a broken motor with a different additive in your oil or lubrication=?
The Cera Tec additive may provide a higher level of "cushioning" between parts when they contact each other, and that's how it quiets down the ticking.
