accel
I've read ceratec helps to some, so I compared my situation to another member's gt symptoms (similar) with ceratec success story and after doubts decided to give it a try.
Some observation on my tick:
It is pronounced on cold engine starts and until the engine completely warms up. By that I mean oil and coolant temperature gauges stop growing. At that point it's either non existent or too quiet to hear.
No ticking at idle. Only low rpm slow accelerations (1000-2000rpms) at 1 and 2nd, or neutral while holding engine ~1750 rpms.
And if after that I stop the engine for some period of time - i.e. go get groceries or something that lets engine cool down a little.... I do not mean get completely cold, - fluid temperatures are still within ranges - oil within green area but closer to the beginning, coolant needle is just not vertical anymore, but you can drive the car without babying it as it will get hot while you are maneuvering through parking lot. So the tick is back until the engine is completely hot again.
And the sound was heard from passenger side with windows down and some obstacle on the right.
I got a bottle of ceratec and decided to give it a try. My engine oil level is almost at top so I only used 30-50% of the bottle... plus I do not like idea of additives. I thought - if it does not work, iI'll change the oil.
Started the engine, let it idle a little to make sure oil and additive get mixed well, then drove.
No tick in usual conditions.
I'll update in several more days to see what the progress will be.
