The adapter is a piece of aluminum and is not even close to the issue... it's the blow by thats going to be evident in any bov setup and it's the blow by that needs to be taken care of. Run a upr (most people swear by) or just vent to atmosphere, wipe down and let the rest burn off.Ditch the BOV adapter.. any turbo car I've had with an adapter on the BOV/BPV leaked oil like that. If you want the sound get an intake or get an entire BOV replacement from turbosmart, hks or Tial.
Sent from my SM-G920P using Tapatalk
Its been burning off for weeks now does it really take that long? The smoke is coming from the exhaustThe adapter is a piece of aluminum and is not even close to the issue... it's the blow by thats going to be evident in any bov setup and it's the blow by that needs to be taken care of. Run a upr (most people swear by) or just vent to atmosphere, wipe down and let the rest burn off.
Couple of questions- when you VTA, where in the system do you disconnect or cut? Will it throw a code with the system open? Also, do the vented filler caps do anything or simply look nice? My car is stock (no smoke problem) but I'd like to eliminate as much of the build up on the intake valves as possible.The adapter is a piece of aluminum and is not even close to the issue... it's the blow by thats going to be evident in any bov setup and it's the blow by that needs to be taken care of. Run a upr (most people swear by) or just vent to atmosphere, wipe down and let the rest burn off.
I have your exact catch can setup and can tell you no it's not supposed to keep burning yet both of our are. That's why I plan on running vta since I feel like spending over 200 is insane for a upr catch can. I plan on capping the intake manifold line and running the out line straight down with spare hose. Looks like there's a threaded bolt hole below the mishimoto catch can position too so I can mount a small bracket to hole the hose in place.Its been burning off for weeks now does it really take that long? The smoke is coming from the exhaust
Sent from my SM-G900P using Tapatalk
hey what did you do to fix it? or what was the problem causing it?So I have oil coming from my BOV adapter and I think I've found the cause of all the white smoke I've been experiencing when I let off. Any ideas on how to clean the oil? or do i just let it burn off?
