Oil Pan Removal/Installation Instructions for BSD
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
I've inlcuded the FSM instructions below with this post for anyone looking to do the Balance Shaft Delete (BSD). You'll basically need to pull the oil pan, unbolt the BS carriage assembly (4 bolts), install the BSD plug and bolt, and then button everything up.
There are several manufacturers that make BSD kits for these engines. Ford Performance (what I use), Mountune, CFM, James Barone, and Massive are a few of the more popular ones. Anything of the BSD kits that work on the EcoBoost, MZR, or Duratec engines will work with this platform as well.
I'm running short on time, but I'll update this post in the future with some links to the more popular BSD kits.
Clicky clicky
LuckyJerk
NY
Michael
2015 Ecoboost Mustang AT
This is great!
Do you have any other doc like this that show step by step procedures for other kinds of work?
Juben
Juben
Chattanooga, TN
Justin
This is great!
I have the entire manual. I've already PDF'd some things, like Intake Manifold removal/installation, that I have on my phone. Other things, like oil pump removal/install, would have to be created.
brimstn
Knoxville, TN
2015 Magnetic Ecoboost
Do you think you could PDF me the brake caliper install pages? Specifically for the GT...I just need the torque values. Upgrading to GT calipers so I need the torque values for the caliper to knuckle, banjo bolt to caliper, and brake line to hard line. Thanks in advance!
Juben
Juben
Chattanooga, TN
Justin
Shoot me a PM with an email address. It'll be late tonight after I get off work, but I'll find it and send it over.
pctek
Northern California
2015 GT Premium DIB 401A
I have a 2015 GT. These instructions are for the Eco-boost. Are the instructions the same? Also, i thought a front end alignment would be needed, but I don't see that in the documented you linked to, Thanks
Juben
Juben
Chattanooga, TN
Justin
You don't have balance shafts to delete in the Coyote engine. If you're looking for instructions to pulling the Coyote oil pan, then no, it wouldn't be the same.
