I do.@GTP snd @thunderstrike - do you guys have active exhaust?
I do not.@GTP snd @thunderstrike - do you guys have active exhaust?
Turn on quiet mode on your exhaust settings, set it to be quiet at the time it currently is, start the car and put it in track mode and then shut it off.No, and I still occasionally have the noise on startup. It sounds like piston knock for a second but I think it could also be the active exhaust closing from its last position, which is often. Sport or track mode.
Did you figure out the concern? Mine is also doing it too. Don’t remember if it did it before or not.Mine does it too.
Not sure I had it before.
Strange.
Any updates??? I been having a mach 1 for 5 months nowHave you ever figured out what was causing the noise? My 2019 GT is also making the same noise.
Did you ever figure out what it was??? Any further issues ??I’ve got a brand new Mustang GT with active exhaust and the 10-speed auto. It’s only got about 390 miles on it so far, and I’ve had it for just three weeks. I’ve noticed an odd startup sound every once in a while. The car seems to slightly stumble on startup and I hear a singe metallic knock sound-it sounds like engine knock but it’s just one single knock noise. Car runs perfectly fine in all respects.
Anyone ever hear this in their Coyote V8? It definitely doesn’t sound normal to me, but I’ll bet it only happens about 1 out of 10-15 starts. Also seems like it’s only happened after I’ve driven it for a period and the engine is warmed up to operating temperature (but not always.)
Hello; New theory. I discovered something with my four-cylinder car years ago. I sometimes would start it up to pull it into the garage a few feet after it had sat long enough for the engine to get cold. I would shut the engine down within moments and for sure before it had warmed up.It’s a rare occurrence and sounds like a rattling piston for like two knocks. Almost like the motor isn’t igniting immediately but once it does all is fine.
