rbkennedy1950
- Nov 26, 2020
- Chapel HIll, NC
- Bob
- 2018 Mustang GT PP1
After two years I purchased a new drain plug but all I really needed was the o-ring on the plug. When I measured the outside diameter of the new and old o-rings, while on the drain plug, the new one measured 12 thousands of an inch bigger, not sure if the old one was worn or the new one was just bigger. The new plug had no problem going in so I imagine it is better than the old one. Does anyone know if you can just purchase the o-ring from Ford or an auto parts store? I go online and find many places that sell o-rings but matching the size is a problem. I may be anal but I want to change the o-ring every time I change the oil, when putting $50 of oil in I don't mind spending another $2. I don't want to hear that the o-ring will last for years or just buy a new drain plug every year I want a replacement o-ring. Someone has to know the size of the o-ring or where we can get them.
Update 1-5-2021. I took some careful measurements of the o-ring from a new drain plug that I ordered. I then searched the web for a manufacture and found globalindustries.com and order a package of 5 O-rings. They fit perfectly although I have not used one yet but I'm sure they will be fine as they measure exactly what the factory one did. The inventory stock # is B2272251. The description is Viton O-Ring Dash 208. A pack of 5 costs about $5 with $5 shipping. I only ordered 5 as I was not sure they were correct but they are so order 10 or 20 and you should be set for life. I would not order any other material other than Viton as it meets the temperature requirements that an engine will submit the O-ring to. The bad news is that because of Covid the Post Office took almost a month to deliver them
