Now available from SCP: Ford Mustang GT Performance Aluminum Radiator
Discussion in 'V8 Bolt-Ons & Tunes' started by Southern Car Parts, Jun 14, 2016.
  1. Southern Car Parts
    Southern Car Parts Well-Known Member
    Vehicle(s):
    2015 6spd GT
    Dec 18, 2014
    Atlanta, GA
    350
    #1 Southern Car Parts, Jun 14, 2016
    2015-2017 Ford Mustang GT Performance Aluminum Radiator
    You have that hot new Mustang and it is making more HP then the factory radiator can handle. We have the answer.
    Cool down your Coyote. The Mustang GT’s Coyote engine is a feat of engineering, but every engine needs to maintain proper engine temperatures. After whining the engine out to its 7,000 RPM redline during some hot laps at the track engine temps will start to rise. The Mishimoto Mustang GT radiator is up to the challenge of keeping temperatures down, even after consecutive laps with the peddle mashed to the floor.
    Direct fit for 2015+ Ford Mustang GT, standard and performance pack models
    Core designed for maximum efficiency over the performance package radiator
    52mm, 3-Row core
    129% increase in coolant capacity over the stock radiator
    77% increase in coolant capacity over the stock performance package radiator
    26% increase in coolant surface area (tubes) over the stock performance package radiator
    55% increase in air surface area (fins) over the stock performance package radiator
    Fully brazed aluminum core
    Fits manual and automatic vehicles
    TIG-welded to perfection
    Includes Magnetic Drain Plug
    Mishimoto Lifetime Warranty
    The 52mm, 3-row core is a massive upgrade over the stock radiator. With a 77% increase in coolant capacity over the stock performance package radiator, overheating won’t be an issue. Launch your GT down the strip as much as you want, and you’ll have the peace of mind that coolant temperatures will be right where they’re supposed to be. This high-quality Mustang GT radiator is backed by the Mishimoto Lifetime Warranty to ensure only the best of the best.
    Order here: 2015 2016 2017 Ford Mustang GT Performance Aluminum Radiator
    wizofwuz and Ruby15GT like this.
  2. OP
    Southern Car Parts
    Vehicle(s):
    2015 6spd GT
    Dec 18, 2014
    Atlanta, GA
    350
Loading...
Share This Page
