BmacIL
Enginerd
- Sep 21, 2014
- Naperville, IL
- 2015 Guard GT Base, M/T
- Vehicle Showcase
- 1
Don't know what to tell you other than you're right about the sidewall needs. If you're gonna run them, run 17". If you were hopping after the 1-2 shift I can only conclude that the surface is odd or you're getting way too much weight transfer/torque split between shifts.NT05R less then a 45 aspect ratio sidewall is pointless. You need to air em down quite a bit. With my 305/35r19 NT05R airing down made the hop much worse, raising the pressure delayed when the hop kicked in (dead hooked, no spin, armageddon wheel hop 1st-4th still managed 115mph). I went way faster on a borrowed set of similar size street radials (NT05) that spun a little outta the dig, with no hop.(119mph).
- 2015 Steeda Mustang IRS Subframe Bushing Support System ~ Yup
- 2015 Steeda Mustang Billet Aluminum Vertical Links ~ nope
- 2015 Steeda Mustang IRS Subframe Support Braces ~ nope
- 2015 Steeda Mustang Adjustable Rear Toe Links ~ nope
- add Drag/ track specific struts-coils
