Grey-Smoke
- Mar 11, 2021
- California
- Chris
- 2021 Mach 1
Question that may be irrelevant (I do that). The oil catch can isn’t yet approved for the Mach 1 by Ford. So, I think that would void the warranty?
I would trust doing anything to your car has potential to void your warranty I’ve heard some good stories and bad with warranty claims. But it’s a easy hose you can take off with one hand. Just keep the other hose Incase you need to swap it back for whatever reason. After seeing the oil it caught I’m convinced it’s better to have then not.
Really easy. Just one stem bolt for mounting to the cam cover and a couple quick clip plugs. Here’s a link to the instructions. They don’t specify Mach 1 but it does for the bullitt which is identical.Grey Smoke,
Do you need to modify any thing or is it plug and play?
Lee
https://www.cjponyparts.com/media/images/install-pdf/install_m6766a50a.pdf
Yeah that would be cool to have it drain back. I found a video of a newer gt350 and it’s the same as mine but it clips on the cam cover instead of changing out a bolt. He did the driver side too but didn’t get any oil in that side.wish this was like my Shelby where it doesn't need to be dumped, it drains it back into oil system
