Newest Part From J&M Products / www.hotpart.com
Hotpart.com
San Luis Obispo, CA
2002, 2006, 2015 Mustangs
J&M Products – 2015-2021 Ford Mustang Adjustable Rear Toe Links
Part # 25411 – Ford Mustang 2015-Present Rear Adjustable Toe Link Fits PP1, PP2, GT350, GT500, & Ford Performance M-5A460-M bearings (Wider Bearing)
Made In The USA
J&M Products IRS Rear Toe Adjustment Links Part # 25411, providing a direct bolt-on upgrade replacement for all S550 Mustangs, including the V6, EcoBoost, Shelby GT350, & GT500 models with the wider Ford Performance toe link bearing part # M-5A460-M. J&M’s Rear Toe Adjustment Links allows you to precisely set toe alignment for your specific driving attitude, improving driving confidence whether on the street or the track. The stock toe adjustment links have a tendency to flex under heavy cornering giving you inconsistent rear toe alignment and irregular, wonky handling characteristics. A perfect addition to any S550 Mustang that has been lowered, sold as a pair with all necessary hardware and instructions.
J&M Products Rear Toe Adjustment Links:
  • Made from high strength DOM steel
  • CNC laser cut and formed ends
  • High strength 1045 tube adapters
  • Rosette and pulse welded tube adapters for superior strength
  • Made in the USA
  • On-Car Adjustable for a full 1″ of Adjustment
  • High Quality pulse-welded Construction
  • Black and Red Powder Coated finish for a long lasting durable finish
  • 52100 heat treated steel/hard chrome plated ball
  • Rod end bodies are constructed of heat treated chrome moly alloy steel with clear zinc plating
  • Bearing liner is a stronger sintered bronze wire net impregnated with PTFE powder, same as modern ball joints.
Fits: 2015 2016 2017 2018 2019 2020 2021 Ford Mustang 2015-Present Rear Adjustable Toe Link Fits PP1, PP2, GT350, GT500, & Ford Performance M-5A460-M bearings
TeeLew
So Cal
Tim
I've got these on my car. Super strong pieces, perfect fit, zero noise & makes setting your toe a piece o' cake. I recommend this as well to speed the adjustments along. The jam-nuts and turnbuckle are bigger than you think.
