Nodster
Hi all
I have a build thread here and I've just finished the install this afternoon. But I have a strange issue. The car turns over, fires, but then instantly dies.
Video
Now my battery is/was flat, but during this work and the writing of the tune I had another car next to me and I was hooked up to its battery so I don't think we can blame my flat battery as the power was coming from the other car. But let me know if we think that actually, that could be the cause.
I've checked over what I can visually.
When it fires, you can smell petrol coming out the back of the exhaust so it seems to be dumping fuel in OK but not sparking to ignite it? I think the wiring for the BAP is connected, it can only really go one way.
@Wengerd Performance is trying to help me. The inital tune didn't work and now I've tried a cut down tune, both exhibt the same starting behaviour. The cut down tune is just calibrated for LU47 injectors with MAF settings. Nothing else.
I'm OK at following instructions but if anyone asks to troubleshoot I'll be a bit useless unless I can be directed (go here, do that, check for this by doing XYZ). So please be gentle with me. @beefcake do your guys have any ideas what might be amiss here?
Any ideas? I followed the instructions to the letter and took my time as well, this is so frustrating.
Thanks.
Video
- Coil packs are connected and look to be seated flush against the engine
- Spark plugs were screwed in and then nipped/torqued to 15nm. (I replaced the OEM spark plugs with NGK LTR7IX-11 IRIDIUM NGK 6510 gapped at 0.028")
- Checked for fuel leaks from the high/low pressure side connections to the rails. All dry.
- Checked the connectors were fastened to all injectors.
- Checked the Throttle body connector was attached.
- Checked the MAF connector (Also, the MAF can only go into the pipe one way as the screw holes won't line up if inserted wrong way up)
- Visually checked the pipe from the top of the throttle body spacer back to the top of the BOV. That is connected.
- Visually checked the two (PCV?) lines back into the intake.
Thanks.
