NEW SYNC 3.0 Build 20204 Nav Android Auto/Apple Carplay
Mustang_Eh
Canada
2019 GT PP2
Does anyone have a download link to working v3 files? Owner.ford.com download is not working. I spoke with Ford and they are not planning on fixing it until MAYBE end of the month or longer. I live in a condo, so wi-fi option doesn't work (takes ~10 days to complete) and I sure as hell won't pay the dealer $100+ to update.
leszek
Kirkland, WA
S550 CO GT PP vert
see my post one page back for the official Ford link
NewTekBuzz
Flint, MI
Tim
2015 Black GT 6M
I am having trouble getting mine to update. I’m currently running Sync 3 v2.2 (16280)
I’ve tried 18025 by itself and I’ve tried the modified 18025 & 18093 install.
I keep getting error code SIGN_ERR01
Any ideas?
Thanks
leszek
Kirkland, WA
S550 CO GT PP vert
Yes, do a factory reset prior to the upgrade and make sure your USB key is formatted to either exfat or fat32.
NewTekBuzz
Flint, MI
Tim
2015 Black GT 6M
ahhh… the factory reset must be the key. ill go give that try and let you know
Thanks
asteele
Canberra, Australia
Ford Mondeo Titanium
Factory reset is not usually required, I have never needed to do it - but it is the first thing to do if things are not working as expected! :)
NewTekBuzz
Flint, MI
Tim
2015 Black GT 6M
Did the reset and still getting errors! Contacted seller of the unit and they said this was a known issue and they are sending me a new unit. Fingers crossed!
Aras
Lake Forest, CA
2016 Mustang GT Premium PP
Not simultaneously. If you switch apps on the phone, Waze will not display on the car's screen. If you switch back to Waze, it will show up again.
Thank you, honestly that implementation sucks
UofMEngineer
Michigan
22' FE, 20' FE
Apple limitation. Third party apps can only stream video when the phone is on and the app is in the foreground. For the curious.
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Here's how to do a full upgrade from any previous 3.x version to 18093. This instructions are for NA NAV sync 3 v3.x (you can extrapolate this for non-NAV if you're savvy enough. For sync 3 v2.x or v1.x you'll have to first install the vanilla 18025 from the link below then run through this procedure. For either non-NAV and/or non-NA builds use the appropriate vanilla 18025)
1) download the full 18025 from Ford
2) extract the zip file into a USB key
3) download the shell-only 18093 update from Ford
4) copy the JR3T-14G381-AM_117055.tar.gz file into the SyncMyRide folder on the USB key (created in step 2)
5) edit autoinstall.lst file on the USB key so that it looks exactly like this:
6) insert the USB key into your car.
This didnt work for me, it kept telling me that my system was already updated (Have the official 18025 build). I did get it updated with just the 18093 file and a different autoinstall.lst file.
Got it updated and tried waze again, and I still have the Audio Volume dropping to 6 when Waze speaks out directions. Anyone else have this problem? Anyone?!?!?!?
leszek
Kirkland, WA
S550 CO GT PP vert
The only way for that to happen that I can think of is if you didn't copy the autoinstall.lst exactly as it is in the thread and instead tried to edit the original 18025 one by hand.
AngelDeath
CH, New Jersey
First round your response was what I did, the second time I copied what you put in the thread and still didnt install either, but I could have done something wrong, the end result I got it installed.
Indylatenight
Greenwood, Indiana
Doug
2016 Ecoboost Premium Convertible
I have the exact same problem since upgrading.
