Tyler@LMR
Introducing The New SVE XS7 Wheels For 2015-2019 Mustangs
(More Info)
Mustang SVE XS7 Wheel
Enrich the styling of your S550 with SVE's latest wheel creation that's sure to raise the standard of what a 2015-2019 Mustang wheel should be. SVE's XS7 wheel provides the perfect blend of high-class styling and track-ready function. Featuring a 7-spoke, concave design; the XS7 wheel flawlessly complements the body lines of your S550 for unmatched styling. These thin, concave spokes glide into a recessed center section with color matched SVE center cap. A stepped barrel provides the added clearance needed for bigger brakes. Meticulously painted in a sleek, Tuxedo Black finish, Ceramic Bronze, or Sterling Graphite; SVE's XS7 wheel is guaranteed to look great on any S550!
Exceptional Fitment & Quality
SVE carefully measured every millimeter of this wheel to ensure the best fit and finish on the market. Designed to not only flow with the body lines of your S550, the XS7 wheel is designed to clear large brake packages. From the backspacing and offset, to the width and diameter, the XS7 wheel provides your Mustang with superior styling and exceptional performance! Constructed using 1-piece, cast aluminum; this wheel is durable and backed by a lifetime structural warranty for the ultimate peace of mind.
Wheel Specs
Backspace: 7"
Offset: +40mm
Weight: 27.2 lbs
Lug Pattern: 5x114.3mm
Brake Fitment
-Will clear Performance Pack and other big brake packages.
-Will NOT fit Shelby GT350/R.
Application
-Fits 2015-2019 Mustang
(More Info)
Wheel Specs
Backspace: 7"
Offset: +40mm
Weight: 27.2 lbs
Brake Fitment
Application
