New supercharger kit from Hamburger's Superchargers premiering at SEMA!
Status
Not open for further replies.
Black Dog
Looking For Trouble
In the Country
Fred
2018 GT Air Cooled Twins by Comp Turbo
Hi. Is this a blower or centrifugal? 90k RPMs are really high. Sounds like a well made system.
Its a turbo with a belt. I don't like belts. But I like this blower setup. Had it been available when I bought my vortech I would of bought this bad boy. The biggest problem which I had with my vortech was the air to air IC it blocked cool air to the engine. This kit gets the IC out of the way. Hot engine is more prone to knock and we all know knock aint good. Finally someone with a brain put together a nice centri blower kit. With lowest IATs this is the kit to go with. Besides turbos. Great job Hamburger I am getting hungry!!! 🍔
illtal
I'm interested in seeing some real world results on this setup.
GregO
Illinois
S550 GTPP
The blower spins 90k rpm, almost twice any other blower speed. It uses a non Newtonian fluid for traction and is a planetary drive setup. You change the fluid every 24k miles.
Is this a Rotrex supercharger ?
What is the total Non-Newtonian fluid capacity ?
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
Nothing for 15-17 Mustangs?
illtal
Google is your friend
A non-Newtonian fluid is a fluid that does not follow Newton's law of viscosity, i.e., constant viscosity independent of stress. In non-Newtonian fluids, viscosity can change when under force to either more liquid or more solid. Ketchup, for example, becomes runnier when shaken and is thus a non-Newtonian fluid.
Honey is another example of a Non-Newtonian fluid
Motor Oil is another example of a non-Newtonian fluid
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
He didn't ask what it was, just how much it holds?
So...how much ketchup that thing take?
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Seems pretty similar to the P1X as far as power capacity. I'm not a fan of where it mounts though, it looks like it would be very difficult to work on like changing a pulley. One of the big reasons I went P1X over other options a year ago.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Would you care for a Hamburger?
itsdapk
itsdapk
Lanoka Harbor
www.hamburgerssuperchargers.com
PK
2020 Mustang, 2021 Jeep Mojave, 2019 Ram
- Air to Water, Nice.
- $7500 100% Complete Kit, from start to finish, Awesome.
- Now we need the specifics as to the quality of the build parts, ETC.
- What type of Supercharger, Roots, Screw ETC.
- What size is the Unit?
- What is the total weight (GAIN) of your kit when installed as compared to prior OEM?
- Driving WOT pulls on Hot Days 85+ F, How is the HEAT Soak Compared to Whipple, VMP ETC?
- Any modification necessary to do the install, Even the smallest mod, Trim this, Mod this ETC?
- How is the efficiency compared to your Competition, what PSI Boost to achieve your numbers
**Im Interested. Email Me @ [email protected]
Theres an empty boss on the passenger side timing cover that needs to be ground down about a 1/4" and the radiator baffles need to be trimmed on the driver side and a hole for the supercharger coolant hose has to be drilled on the passenger side radiator baffle. The factory radiator fan is cut but it is included with the kit and there is no core for the old one.
DougS550
Indiana
Doug
2019 GT PP Whipple Stage 2
Hi. What do you mean the radiator fan blade has to be cut? What core are you talking about and exactly what is done to it?
itsdapk
itsdapk
Lanoka Harbor
PK
Thx,
The picture posted did not have the Rotrex name casted into the housing.
Nonetheless, I like everything about this kit.
The scroll and impeller is a custom made for Hamburgers.
We send a new modified fan/shroud. So your stock one comes off so you can put it back to stock if needed..
Status
