• Welcome to Mustang7G!
    If you're joining us from Mustang6G, then you may already have an account here!
    As long as you were registered on Mustang6G as of March 10, 2021 or earlier, then you can simply login here with the same username and password!
Ace
Germany
www.modernmusclecars.de
2023 C8 Stingray
With the new spyshots available I tried to update my last rendering as good as possible. I added two sketches what I think the lines of the frontend might look like.
S650 Mustang New S650 Rendering (based on first spyshots) skizze_side
S650 Mustang New S650 Rendering (based on first spyshots) front_05
Here's how I imagine the car could look like without any camo.
S650 Mustang New S650 Rendering (based on first spyshots) Mustang7_Red_ModernMuscleCars_v3
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
Not a fan of the back ridge over the rear wheels, hoping its a little more subdued than your render. Thanks for playing Ace!
Twin Turbo
Super Moderator
Moderator
England
Mustang '05 GT
Jem mentioned the corner pockets/air intakes in the front bumper are much like the Mach 1. Perhaps when the camo drops a little more, we'll be able to see this. As it stands, your render certainly captures what "appears" to be under the camo though :like:
EFI
Masshole central
5.Br0
If *that* is truly it, then it's basically a front end refresh similar to the 2018, and sadly one that makes it look more like a Camaro than the Mustang.
I sure hope the mechanicals are where the real upgrades are, cuz it would be a shame to call this a new generation.
93-Oct Mayne
DC
2024 Mustang GT
I wish I could do that! This is really good. I think the headlights will be a couple inches taller toward the grille and maybe sit a bit lower in relation to the hood, also it doesn't look like that crease over the rear quarter panel will be there
Jem
Traveler
S550 GT
It may not look like much in 2d with what looks like grade 3 art skill, I did in about 3 minutes, but imagine in 3d, in the metal, with some tweaked sculpting and visualize the aggressive tail lamp treatment...
I think it will be a decent looker 😉
Ace
Ace
Germany
2023 C8 Stingray
Im thinking something like this for the rear based on what i see on new spy pics and giving the mach e a harder edge..
Yeah, that looks possible. But I could totally see Ford messing with us by using padding that adds lines that arent there
Currently I am thinking the additional edge on the side of the rear could give the car a bit of a Camaro look:
S650 Mustang New S650 Rendering (based on first spyshots) 1642412079909
shogun32
Northern VA
2019 GT+PP, SS+1LE, 2020 F150
Hello Camaro. The headlights need t be below the wheel rim though.
At least the 'mouth' isn't an obscene size but I sure hope Ford doesn't screw up the greenhouse. High sills are NOT desirable.
because_murica
United States
2013 Camaro SS-1LE
This one has been making the rounds - legitimacy unknown
I'm in if it's similar to this. Although this is obviously just based on S550, the headlight shape seems pretty close to that of the proto (from what we can guess at least).
