New LMR SVE SP2 Wheels (PP2 Replica)
opengl
PA
2018 GT PP1 400A 6MT
Definitely tramlining. Though I can't say I've really noticed it on mine much, but I came from PP1 wheels.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
Yep, sounds like that. No way to avoid that right? Any others notice this also?
Get a bumpsteer kit with the steeda front links with the extended ball stud. This will help your steering / feeling all those bumps. Just another mod to add to the list when lowering.
Might as well get a set of BMR camber bolts while your at it. Or you can do plates but bolts are sufficient for street use. Lots of OEMs use bolts to adjust front camber right from the factory... Since I know someone is going to say uhhh bolts are bad mmmkay lol.
It makes a big difference.
Blade007
North East
2017 Mustang Ecoboost Magnetic, 2011 Nissan quest
thanks for the advice. Will have to get those installed asap
Dave TBG
Patiently waiting...
New Jersey
'19 EB 201A, '86 Porsche 944
I really haven't noticed tramlining, but I do have the extended ball joints and I'm only a half inch lower than stock
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
Tramlining and bumpsteer are two different animals. Tramlining is a sideeffect a lot of the times due to alignment and wider front tires.
Dr. Norts
Ontario, Canada
Are you running those without a bumpsteer kit?
The two go hand in hand. Don't do one without the other.
Dave TBG
New Jersey
My understanding is that the extended ball joints move the pivot point 3/8-1/2" so they are beneficial for cars that have been lowered that distance or more, but the bump steer kit is only necessary for cars that are lowered more than 3/4". I'm only lowered 1/2", maybe a hair less, and am not looking to fix a problem that I don't have.
Twenty4/7
Central Florida
Robert
2021 RR GT500
my car tramlines pretty bad on roads that are worn badly from truck tires. ive had the 295's up front with full stock pp1 suspenion and with steeda full suspension (lower control arms and bumpsteer kit). seems to be exactly the same
NeedForGreen
2019 Mustang GT
The tramlining may actually get better. I had rtr wheels installed and had horrible tramlining. It did improve to almost nothing after putting some miles on the car. Between the alignment and the new wheels I think the tires just needed to adjust/wear in.
codereddew
2019 Mustang GT PP1
Got mine installed today :) now all she needs is some lowering springs
19x10 squared on 285/35/19 Michelin PS4S tires
