- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
MMR's GT350 / GT350R & Mach 1 Hose adapters allow you to plumb both your TR-3160 transmission oil cooler and Differential oil cooler with AN style lines, this is perfect for those using the TR3160 Transmission in other applications such as Mustang GT or Kit cars. When used on the factory differential oil pump you can now plumb a larger cooler using AN style lines and fittings.
Features:
Accepts -8AN Fitting
Double Oring design for leak free seal
Bolts directly to transmission or Differential oil pump
Anodized for Corrosion Resistance
Includes 2 Fittings with O rings & Hardware
Does NOT fit 2016 (non cooler) GT350 transmissions
Features:
