New cold air kit from PMAS No tune required.
Discussion in 'V8 Bolt-Ons & Tunes' started by PMAS, Apr 28, 2015.
  1. Brent302
    Brent302 Well-Known Member
    Vehicle(s):
    2015 Mustang GT/PP
    May 13, 2014
    Springfield VA
    3,539
    396
    0   0   0
    I spoke with him earlier. It is a tight fit but as long as you make sure the tube is laying on the shroud pretty much you'll be good. I just did a short drop and it closed fine. He was a little nervous but I'm sure with my advice he will be fine on the reinstall.
  2. RomanB
    RomanB Well-Known Member
    Vehicle(s):
    2015 5.0
    Jul 5, 2015
    Casa Grande AZ
    226
    44
    0   0   0
    Will try again tomorrow after work... Good thing is it fired right up, IATs were good and AFRs were good. Then I tried closing the hood... No matter what you do, the hood liner will apply pressure on the intake and there will be a significant amount of resistance. I tied adjusting it several times and I was never comfortable applying any more pressure on the hood.
    Brent302 likes this.
  3. OP
    PMAS
    PMAS Well-Known Member
    Vehicle(s):
    multiple
    Apr 28, 2015
    Eaton Rapids, MI
    282
    240
    0   0   0
    You need to make sure the transition hose is fully angled on the tube. it needs to be slid on as far as it will go on the bottom. the top section of the hose edge will line up with the ledge on the plastic tube. When you push the tube on to the throttle body make sure it is pressed all the way on the throttle body. then while pushing the elbow forward and down onto the fan shroud, tighten the TB clamp. 20150722_125902.jpg 20150722_125831.jpg 20150722_125821.jpg
  4. RomanB
    Vehicle(s):
    2015 5.0
    Jul 5, 2015
    Casa Grande AZ
    226
    44
    0   0   0
    So no where in the directions did it state that the coupler needed to be installed at an angle on the intake tube. That led me to believe that the couple was not cut to the proper size so though my thought process I trimmed it. What are the two sizes on the coupler just in case I trimmed to much?
  5. OP
    PMAS
    Vehicle(s):
    multiple
    Apr 28, 2015
    Eaton Rapids, MI
    282
    240
    0   0   0
    The coupler comes pre installed and clamped tight on the tube for that reason. We will add the note in the instructions though, thank you.
    I'm not sure what dimension you're talking about?
  6. RomanB
    Vehicle(s):
    2015 5.0
    Jul 5, 2015
    Casa Grande AZ
    226
    44
    0   0   0
    The transition hose size?It seems like the intake side is larger then the TB side or is just stretched out? Just in case I need to go buy another coupler. I removed the coupler to smoothen out the cut on the throttle body side. it was crooked jagged and not strait. little did I know...
  7. OP
    PMAS
    Vehicle(s):
    multiple
    Apr 28, 2015
    Eaton Rapids, MI
    282
    240
    0   0   0
    Oh, yes, one side is 4" and one side is 3.5" We can send another coupler if you want. It might be faster to find one locally though.
  8. RomanB
    Vehicle(s):
    2015 5.0
    Jul 5, 2015
    Casa Grande AZ
    226
    44
    0   0   0
    I will head to napa after work, If I cant find one locally I will send you a PM thanks
  9. OP
    PMAS
    Vehicle(s):
    multiple
    Apr 28, 2015
    Eaton Rapids, MI
    282
    240
    0   0   0
    No prob, just let us know!
  10. RomanB
    Vehicle(s):
    2015 5.0
    Jul 5, 2015
    Casa Grande AZ
    226
    44
    0   0   0
    Install was a success. I was able to reuse the trimmed coupler and the car started and idled with proper IATs... Only thing I am concerned about is the bottom vaccum line FITTING is slightly loose. Is that a huge deal PMAS? SHOULD I pull it off and put some. Thread tape on it?
  11. OP
    PMAS
    Vehicle(s):
    multiple
    Apr 28, 2015
    Eaton Rapids, MI
    282
    240
    0   0   0
    Thread tape. it is hard to have a threaded fitting end up pointing in the correct direction and be tight at the same time.
  12. RomanB
    Vehicle(s):
    2015 5.0
    Jul 5, 2015
    Casa Grande AZ
    226
    44
    0   0   0
    PMAS please respond to my Private message
  13. Brent302
    Vehicle(s):
    2015 Mustang GT/PP
    May 13, 2014
    Springfield VA
    3,539
    396
    0   0   0
    Once it's connected it's not going to untwist mine was like that day 1 and it's still connected. [emoji106]
  14. Jayme
    Jayme DoggystyleRacing®
    First Name:
    Jayme
    Vehicle(s):
    2015 Mustang GT
    May 24, 2015
    Baytown, TX
    447
    78
    0   0   0
    Ever get any pics Roman?
  15. aggieStang
    aggieStang Well-Known Member
    Vehicle(s):
    2015 Mustang GT, 1965 Mustang Coupe
    Jan 6, 2015
    Refugio, TX
    749
    196
    0   0   0
    Add another one to the successfull install list! Today was like christmas in july[​IMG]
    I installed it super quick! No issues. Ive got a few pics if anyone is interested
    souprmage and sndofprogress like this.
Loading...
Share This Page
