Swoope
Zoom-Freakin'-Zoom
the rotary is a different beast, but the recommended was 5/30. all the track rx8 guys i know run 15/40 rotella. or 20/50 other brand. the rotella is something a rotary guru came up with. but works.. change oil after every track weekend.On my 350Z I've been using Mobil-1 10/30 with changes every 5000 miles or after every couple of track days. It's been working great for over 180,000 miles, so I don't plan on changing.
However, I do notice that at the track, when exiting after a session and the car is idling, the oil pressure will be extremely low.
Then, as I was following the C7 launch, I saw that GM recommends going to 15/50 oil for track use, which is much heavier than their standard recommendation.
I did not see such a recommendation in the 2015 Mustang manual, but using a 5/20 for the track seems sketchy given what I see with my Z.
Just curious what people do on their Mustangs when going to the track. Do you use a heavier weight oil, or stick with what is in the manual? I did notice some mention of a heavier recommended oil for the PP cars in previous years, so maybe that would be a good starting point for track use. How about the Boss 302? What oil did it recommend?
-T
this is what i have been doing since i have just been using car on track.
before that and the first ~60k miles it was 10/40 royal purple changed at 5k.
if i get a mustang will likely run 10/40 semi syn. and change at 5k or after every track weekend which ever comes first.
btw, i just found a shown in inventory the exact car i would order for track at my local dealer that i have been chatting with. fate?
beers
