Bsingh897
- May 26, 2017
- California
- 2017 mustang gt
First of all: If you guys remember I toasted my radio but got a used one from eBay and everything runs and well to go! I will be upgrading my four speakers (2x Front, 2x Rear) and the tweeters. I will also purchase a subwoofer with custom built enclosure for my mustang. I will provide photos and specification of the products. I currently have stock Sync system. I am very new to this audio setup, so please explain it as simple as it can be. Thank you for your patient. I try to provide as much information as i can but please let me know if i can provide anything else.
Things I will do:
My Questions:
Subwoofer Amplifier
Technical Specifications
Subwoofer:
Specifications
Skar Audio SDR-10 D4 - 10" Component Car Subwoofer
Dual 4 Ohm Voice Coil Configuration
Peak Power: 1200 Watts
RMS Power: 600 Watts
Competition Grade Pressed Paper Cone
Stitched High Roll Foam Surround
Advanced Air Flow Cooling System
2.5" High Temperature Copper Voice Coil
Frequency Response: 39 - 300 Hz
Sensitivity: 82.5 dB
Fs: 39 Hz
Re: 3.2 Ohms
Qms: 6.08
Qes: 0.68
Qts: 0.61
Nref: %
Cms: 0.079 mm/N
Bl: 10.9 n/a
Vas: 11 L
Mms: 188.75 gr
Sd: 298.65 cm²
Xmax: 13.5 mm
Enclosure:
Fits 2015+ Mustang Coupe
Amplifier mounts to the back of the faceplate
This listing is for our Version 2 model - This model comes with recessed
subwoofer mounting holes. The subwoofer will recess 0.75" into the face
Mounting Hole cutout for 12" Sub(s): 11 1/8"
Mounting Hole cutout for 10" Sub(s): 9 1/8"
Mounting Hole cutout for 8" Sub(s): 7 1/8"
(This is the most common hole size - We can change size if requested)
Subwoofer Mounting Depth: 7.0"
Airspace Volume: 0.87 cubic ft. Per Subwoofer/Chamber
(Airspace can be reduced if requested)
Entire Box Made with 3/4" MDF
Front Speaker/Tweeters:
SPX-6.5 Technical Information
SPX-6.5 Mounting Information
Mid-Range Mounting Specificaitons
Mounting Depth : 2.64"
Mounting Cut-Out : 5.71"
Magnet Diameter : 3.54"
Overall Depth : 3.05"
Tweeter Mounting Specifications
Mounting Depth : 0.75"
Mounting Cut Out : 2.13"
Overall Depth : 1.0"
Crossover Mounting Specificaitons
Length : 4.92"
Height : 1.37"
Depth : 3.72"
Rear Speakers
Description
The PAX65-4 delivers unparalleled performance in a 6.5-inch pro audio driver that is extremely powerful and lightweight. Engineered to be efficient without sacrificing power or performance, this driver utilizes an extremely efficient neodymium motor, which is complimented by a 2-inch KSV high temperature voice coil. This speaker also features a custom tooled aluminum heatsink for added thermal cooling, and high quality push terminals for an easier connection. Single 4 Ohm voice coil configuration. Frequency Response: 85Hz - 8 kHz. Sensitivity: 94.8 dB. Sold Each.
Outside Diameter: 6.6" (168mm)
Mounting Depth: 3.1" (80mm)
Magnet Diameter: 3.3" (85mm)
Cut Out Diameter: 5.8" (148mm)
Skar Audio PAX65-4 6.5" Pro Audio Midrange Speaker
Impedance: 4 Ohms
Sold Individually
RMS Power: 260 Watts
Peak Power: 520 Watts
Magnet Material: Neodymium
6 Layer High Quality Spider
Useable Frequency Range: 85 Hz - 8 kHz
Sensitivity: 94.8 dB 1W/1m
2" KSV Voice Coil 2L/2T
10MM Top & Back Plate
Spring Push Terminals
Amp to Power Speakers:
Specifications
AudioControl LC7i Black 6-Channel Line Output Converter with Bass Restoration
Things I will do:
- I will tap in behind the sync module to get the inputs and the outputs. I will be using Speedwire.
- I will be using 0 Guage and distributor block to 2x 4 gauge wires to power both amplifiers. I will be using this distribution block: https://www.ebay.com/itm/NEW-STINGER-0G-TO-4-GAUGE-POWER-GROUND-AMP-CABLE-DISTRIBUTION-BLOCK-W-COVER/302821071152?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
My Questions:
- My tweeters and woofers are connected together and powered together according from the electrical diagram? Whats the best way to power the tweeters? Active? Passive? Etc? Where do i physically plug them?
- I hear stuff about the mustangs making fake engine sound/noise and its amplified if you have aftermarket speaker setup. How can that be turned off?
- Also hear about subwoofer will be hissing when the engine is off, i forgot the term but it can be turned off i just cannot rember what it was?
- Are there any other advise/tips to prepare me and make this smooth as it can be?
Subwoofer Amplifier
- Skar Audio RP-800.1D Monoblock Amplifier
- Class D Circuitry Design
- RMS Power @ 1 Ohms : 800 Watts x 1 Channels
- RMS Power @ 2 Ohms : 600 Watts x 1 Channels
- RMS Power @ 4 Ohms : 370 Watts x 1 Channels
- Soft Turn on Circuit
- MOSFET Power Supply
- Tri-Mode Capable / Bridgeable
- Low Pass Filter (Variable) : 50Hz~220Hz
- Subsonic Filter : Off~50Hz
- Adjustable High Quality Gain Control
- Bass EQ Control : 0dB/6dB/12dB
- 8 Gauge Power and Ground Input Terminals
- Allen Screw Set for Easy Installation
- Operational Voltage : 8.5v-14.4v
- Remote Bass Knob & Wire Included
Subwoofer:
Specifications
Fs: 39 Hz
Re: 3.2 Ohms
Qms: 6.08
Qes: 0.68
Qts: 0.61
Nref: %
Cms: 0.079 mm/N
Bl: 10.9 n/a
Vas: 11 L
Mms: 188.75 gr
Sd: 298.65 cm²
Xmax: 13.5 mm
Enclosure:
- Die Cast Aluminum Basket with Diamond Cut Chrome Finish
- High Quality Butyl Rubber Surround
- PMI Composite Multi-Layered Cone
- 1.35" High Temperature Voice Coil
- 25mm (1") Neodymium Magnet and Aluminum Dome Tweeter
- 12dB Passive Crossover Network
- Impedance : 4 Ohms
- Premium 2 Way Component Speaker System
- Frequency Response :42-20,000 Hz
- Sensitivity : 92 dB
- RMS Power : 200 Watts (Pair)
- Max Power : 400 Watts (Pair)
Length : 4.92"
Height : 1.37"
Depth : 3.72"
Rear Speakers
Description
Impedance: 4 Ohms
Sold Individually
Specifications
- Skar Audio RP-150.4AB Multichannel Amplifier
- Class AB 4 Channel Amplifier
- 4 Way Protection Circuitry : Thermal, Voltage, Speaker, DC
- RMS Power @ 4 Ohms : 150 Watts x 4 Channels (14.4v)
- RMS Power @ 2 Ohm : 250 Watts x 4 Channels (14.4v)
- RMS Power @ 4 Ohms (Bridged) : 500 Watts x 2 Channels (14.4v)
- Frequency Response : 20Hz~20kHz
- Signal to Noise Ratio : 105dB
- Low Pass Filter (Variable) : 50Hz~500Hz
- High Pass Filter (Variable) : 20Hz~5kHz
- 4 Gauge Power and Ground Terminals
- Working Voltage : 8.5V-14.4V
- Fuse Rating : 120 Amp
- Dimensions : 19-1/4" (Length) x 7" (Width) x 3" (Height)
- 6-channel line output converter plus bass restoration
- 6 speaker-level inputs (each can handle up to 400 watts RMS)
- Internal channel summing
- AccuBASS bass restoration circuitry
- 6 preamp outputs (up to 8.5 volts RMS)
- Level matching controls with Maximized Indicator LED
- 8-11/16"W x 1-3/8"H x 6-9/16"D
