My Whipple Install Last Week
The Game
Virginia
Garrett
2015 Mustang GT PP
Sorry for the delay on my progress. I received my Stage 2 Whipple Kit with the Flare tool, 3.625" pulley,upgraded fans and IC pump from Lethal Performance back around April 9 and just installed it last Friday into the early hours of Saturday. I work in the oilfield so needless to say I'm gone a lot! I also ordered MMR OPGs, crank sprocket, and their balancer pulley to do at the same time.
After 21 straight days of working a total of 257 hours I got to come home last Thursday. I went to my buddy's shop and we began the tear down at 1:30 PM for the OPGs. By 5 PM we had the car timed and the timing cover back on! We began at 8 AM Friday with the Whipple install. Overall it wasn't a bad project. My manual was dated for Feb but there were a few variances here and there but we figured it out.
Easier Method of Timing the motor:
Use white out to mark all the spots where the chains are on the cams and crank sprocket. Fairly easy given the colored links of the chains. Unbolt 1 front cam retainer on each head, tear a piece of paper big enough to cover the exposed section of each cam(maybe a 2"x3" piece) and bolt it down on the cam. Press your tensioners in and pin them to remove the chains. Nothing moves and your motor is still in time. All you have to do is put your chains on using the colored links as guides to the cams and mark on the crank sprocket. Just remember to take the paper out before you put your valve covers back on.
The only missing piece in the kit was the 6AN Viton fitting that is for the EVAP manifold. We were almost dead in the water without it until we went to a local hose and fitting shop. For $28 I had a steel braided line and fitting made to get me by, and it worked! By 3:30 AM Saturday we fired her up and I was on the road! Had to get 25A fuses for the fan/IC relays to come on but that was the only setback post install! Monday I emailed Whipple and they overnighted me the fitting and I'm now running it with the intended hose. I also have the bypass restrictor on the way as I do have the hesitation a lot are seeing.
I left my home in VA Wednesday night to drive 286 miles to Ohio for my current work rotation and I got 20.6 mpg. Amazing considering the amount of up and down mountains I travel on(150 miles until I reach I-77 in Charleston, WV). The car drives amazing and has better mannerisms than a stock tune! Wednesday morning we installed my DSS Carbon Driveshaft as well. No NVH whatsoever! I just need to get a McLeod RXT, half shafts, and some suspension mods. Can't thank members on here and our Facebook Whipple S550 group for all the tips and answers! Jason Martin was always there to help and answer questions and the customer service at Whipple can't be beat!
kiko1
Miami, Fl
2015 GT auto
looks great!
mumbles
ATL
Eric
'16 GT Prem OW
Nice work on the Whipple and wanted to add that you and your buddy approached the install(s) the smart way... doing the OPGs, testing then doing the Whipple. If you had just done everything at one time and then had problems, it is much harder to determine what caused them.
The Game
Virginia
Garrett
2015 Mustang GT PP
Thanks guys! We tried to use our heads on this one lol. I was nervous as hell ripping into a new car like this. I was also taught a new time saver trick when removing the chains and tensioners to do OPGs. Unbolt 1 front cam retainer on each head, tear a piece of paper big enough to cover the exposed section of each cam(maybe a 2"x3" piece) and bolt it down on the cam. Press your tensioners in and pin them to remove the chains. Nothing moves and your motor is still in time. All you have to do is put your chains on using the colored links as guides. Just remember to take the paper out before you put your valve covers back on.
DrDing.Muscle
Hampton, VA
Tyler
2015 Premium GT PP Competition Orange
Have you noticed any kind of a whine coming from the engine since you did the OPG and TG? I just had mine done in preparation for my whipple as well and now my engine has a whine and I feel it is coming from the oil pump. Nice install by the way. I am also in VA. What part of VA are you in?
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
Honestly, the eval solenoid can be tapped off and not used. I had to do that for a day or two with mine. No issues with it. But glad you got a workaround with it! Looking sick!
The Game
Virginia
Garrett
2015 Mustang GT PP
I don't hear any whine other than the Whipple at idle. Thanks, it was certainly a project. I'm over on the other side of the state, 5 minutes from the KY state line lol.
The Game
Virginia
Garrett
2015 Mustang GT PP
Thanks bud! There's always a way around something haha!
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
Very nice. congrats man
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Thanks for the write and tips as well. You guys did a great job installing both OPG and whipple in the timeframe you mentioned. I did this over the winter and took about a month for me pecking away at it here and there as I was waiting for my kit.
The Game
Virginia
Garrett
2015 Mustang GT PP
The Game
Virginia
Garrett
2015 Mustang GT PP
Thanks! I was dying knowing I had my kit at home waiting all that time. My buddy runs his own garage and made sure he had a rack for me to use. We busted ass and knuckles to make sure we got it done! I'm telling ya, I'm still stunned when he showed me how to use paper to hold the cams in place lol. Simplified and speed the process up in spades!!
CDIZX3
Pittsburgh, PA
2015 GT PP
Looks good. Did mine a couple weekends ago. Everything you did except the dampener. The gears weren't bad except for tearing apart a motor that had 8k miles. ;)
