It's a 1960s repro badge, with some red accents.Is the badge something you made as well?
Appreciate the tips brother. Was only able to stay on the track a little over 20 mins at a time the other weekend without the dreaded over temp limp mode. lolYeah, it's really not too bad. I'd recommend just getting a few extra random straight and right-angle AN adapters. Once your're in there, you'll find easier ways to do everything, and having some extra adapter options makes that a bit easier.
Yeah, sucks for sure. Within 30 seconds of turning my pump on, the temp starts dropping. It usually only takes maybe 3 minutes for it to go from 230 to sub 200, and I can usually get it to sub 170 if I leave it on for a bit.Appreciate the tips brother. Was only able to stay on the track a little over 20 mins at a time the other weekend without the dreaded over temp limp mode. lol
I installed the AC spoiler with wicker bill on mine. Used factory holes, hardest thing was removing the oem tech pack "spoiler".Awesome build! I am torn between the anderson composite gt350 trunk spoiler and the anderson composite gt350r oe sized spoiler (which is an OEM replica/much larger than the other wing) to replace the track pack spoiler that i have with a zl1 wickerbill. When you removed the factory spoiler did the anderson composite bolt right on the factory holes? Did you have to drill any more to bolt on the 3 provided screws? Thanks man.
Finally had the time to get it done! Thanks for your help man, the trial run will be at Sebring next monthAwesome man thanks! Sounds pretty close to what I was thinking and the plumbing details are very helpful as well. I was thinking about buying the FP version then realized the lines and fittings are not going to work without modification for my application and the FP cooler itself is like $200 more than the CX version for basically the brackets. lol
Looks great! Nicely done.I installed the AC spoiler with wicker bill on mine. Used factory holes, hardest thing was removing the oem tech pack "spoiler".
Nice! Glad you found it useful. Good luck, and let me know how you make out!Finally had the time to get it done! Thanks for your help man, the trial run will be at Sebring next month
Thanks!Awesome build! I am torn between the anderson composite gt350 trunk spoiler and the anderson composite gt350r oe sized spoiler (which is an OEM replica/much larger than the other wing) to replace the track pack spoiler that i have with a zl1 wickerbill. When you removed the factory spoiler did the anderson composite bolt right on the factory holes? Did you have to drill any more to bolt on the 3 provided screws? Thanks man.
Thanks!Looks great! Nicely done.
Just an update, ran at Sebring in 84 degree temps and transmission cooler worked great! Thanks for the tips, it was a big relief not to see the dreaded Limp Mode.
