Wamp
Thanks for the D4 infoā¦ had been wondering how some of these things go on the D4.I have a 2018 with the newer MT82-D4. I swapped to Steeda clutch spring as soon as I got the car. The clutch on 2018+ definitely feels different (much lighter) compared to 15-17. However the engagement point was kind of vague so the Steeda spring made an improvement in that aspect. My only gripe with the Steeda spring is that the clutch feels heavy at times and takes lot of effort to engage, I have no issues with it but most of my friends complain When I drive my friends cars like the Golf R and WRX STI, I realize how light their clutches are lol
The next thing I did was BG Syncroshift trans fluid which made slight improvement in the cold weather but nothing to write about. A year later I did the MGW X-spec. I did notice a increase in vibration from the shifter and it was very stiff for the first few days. After a few days it probably broke in, and also changed the knob to MGW gripper spherical knob. At this point, it just felt perfect. It was so smooth, the shifts were buttery smooth and precise, I simply loved it. The fun wouldn't last long however, soon after I dropped my car at the dealership to replace shift forks. The dealer probably put OEM trans fluid back in again. I was kind of lazy for a year to change it back but I definitely didn't like the way how my car shifted during this period.
So once again I switched back to BG Syncroshift fluid a month ago and definitely noticed the difference. My MGW shifter still doesn't feel like the way it did before the shift forks replacement but it works great with BG Syncroshift fluid so I'd HIGHLY recommend it
The steeda clutch to master cylinder line was a PITA to install lol. I spend a good hour cursing but couldn't get one of the clip to press in, so finally used a ziptie at that end. It didn't make any difference whatsoever
The next thing I have on my to-do list is Stainless clutch line.
I agree with @krishelnino, the Steeda line was a massive pain. The only improvement is peace of mind that the stock one wonāt seep any more as the fluid heats up. After seeing the stock line leaking and almost falling off (it was barely hanging on), I wouldnāt want to do a track day or drive too aggressively with the stock line.@krishelnino, I also have the Steeda clutch master cylinder line (packed away in my tool chest) and have been putting off installing it because of the tight fit to get the clip on the hose at the firewall end. If you had this to do over again, would you have left the factory line in place?
It fixed no symptoms, but it almost made me sick looking at the stock line barely hanging on.
Also, +1 about not being able to get the lower clip. I took it off and spend half hour trying to tighten a metal screw type clamp with a swivel ratchetā¦ but I didnāt want to have that coming off either.
