Commbubba19
Makes sense. Otherwise it wouldn’t work.guessing you’ve never seen the Brembo dust shields? That's them in the picture. LOL.
doesn’t change anything else I said though.
Do they still make the Blue? I thought they stopped making it. Google here I come...It depends on how fast you want to go. Back in 1995 my cobra mustang had four piston calipers and were considered to be the best available on a production car. Times change and tech. is improved. I am a firm believer in learning your cars limits before you mod anything. The best mod is you and that is called seat time. However, to start with just change the pads to a track type pad and upgrade the rotors to high carbon slotted rotors. Bleed the brake fluid with some dot 4 fluid. I use the color change method. I flush out the brake system using Blue ATE dot 4 and when the color is nice and blue I know i have done a good flush. Then the next time out I use Motul dot 4, when the color is nice and gold in color I know its been flushed. You get the pitcher. .
I would bet money on a proper S197 Brembo setup coming out on top in a comparison. Better pad options and cooling availability.The standard GT brakes are pretty good. In fact the standard GT brakes on the 15+ cars are quite an improvement over my '14 Brembo brakes.
You should have no problem tracking those brakes, but I would get pads meant for the track and swap the brake fluid out every few times. Just my opinion.
Motul DOT4.0 Is in the car now, pads still in the process of investigation.. at this point I am thinking Hawk DTC60 or DTC70. Any other suggests? Other brands?It depends on how fast you want to go. Back in 1995 my cobra mustang had four piston calipers and were considered to be the best available on a production car. Times change and tech. is improved. I am a firm believer in learning your cars limits before you mod anything. The best mod is you and that is called seat time. However, to start with just change the pads to a track type pad and upgrade the rotors to high carbon slotted rotors. Bleed the brake fluid with some dot 4 fluid. I use the color change method. I flush out the brake system using Blue ATE dot 4 and when the color is nice and blue I know i have done a good flush. Then the next time out I use Motul dot 4, when the color is nice and gold in color I know its been flushed. You get the pitcher. .
I have been in track days before, is just is my first proper project (paid by me) and not borrowed cars. The stock brakes are perfect to my level I think. The pads and rotors are my complain. I have putted Motul Dot4.0 for next track day and have decided to keep OE rotors until they fail. Pads wise I am considering Hawk's DTC 60 or 70. Do you have another suggestion? I am using for next track day Pirelli's Trofeo RRight. Vorslag tested with stock GT brakes, the PP brakes, and a 2 pc rotor big brake upgrade. Result - when driven hard by a experianced track driver, the stock GT brakes give up after a handful of laps. The PP brakes hold up way better but pad wear is a bit high, and maybe they get a little soft at the end of a long, demanding session. The race brakes provide more stopping power and better pad life (maybe not a fair comparison given they also had cooling ducts).
If you have never been on track before the stock GT brakes are probably OK. But as your confidence and experiance improves, you will want to updrade them if you want to keep getting faster. They tested upgraded pads and they weren't a big help.
I think PP brakes + cooling and/or more track oriented pads is enough for most people. Pure stock works well up to MPSS class tires.
If you are really fast and are running Slicks or semi-slick Hoosiers, high end/GT350 brakes might be worth the extra money.
Yes ive seen the video and read the information. Something in Vorshlag's review mentions is that the issue is not the caliper itself, but the rotor. I would like to understand if keeping caliper and changing rotor would be sufficient at least at my current skill level. My next step is to change pads. Do you have any suggestion. At top I have Hawk's DTC60 or 70Do they still make the Blue? I thought they stopped making it. Google here I come...
Read this: https://www.vorshlag.com/forums/for...0-brakes-uses-limitaitons-and-upgrade-options
"I ran these stock 14" brakes with the brand new factory pads and the teenie tiny 235mm wide base GT mud and snow rated tires and they lasted 8 laps on a "brake easy" track, in our first track test # 1. EIGHT LAPS. After the 7th laps in that first test session they were no longer capable of stopping the car at even my mild .85 g stops. I almost went off track, so I came in. The (Motul RBF600) fluid we had in there never boiled, I never had a "soft pedal", the damn car just wouldn't stop anymore."
If you are going to track it for casual fun, maybe you'll be OK with pads and fluid with your reverse hat rotors. Otherwise, investigate the options listed for PP take offs. If you upgrade the calipers I believe you also need to upgrade the master cylinder. I think Vorshlag covers that as well (I wasn't about to read the whole thing...again).
I did not find DTC 50 at Hawk's page. For my car only available HB802G.661 which is DTC60 (or 70) and DTC30 I believe only for rears. That's why I am saying DTC60, and read in other articles that this is based only on th weight of the car so heating brakes is common and 60/70 are better for temperatures reached. You are mentioning DTC50, where did you find those? Mine is 4 pots front calipersIf your car is largely stock DTC60 or 70 are far beyond what you should be looking at. My car is highly modified and runs lap times that are class winning numbers in Time Attack and I run DTC50/DTC30. I get about .5 mm of wear for a track day on the fronts, rears are barely measureable. You need brake cooling though, I would suggest that you work on that right off the bat. I have the FTBR kit and it made a huge difference.
I bought them from a Hawk dealer in Toronto, they sell to a very large racer group and they recommended the 50s over the 60s for my car. The 50 and 60 are very close together in the amount of heat they can sustain, the curves were available on Hawk's website. But the 60 is a lot more aggressive pad and for a completely stock car it is too much pad, the rest of the brake system is not going to like the massive heat it can generate. I could probably use the 60s as I have cooling ducts but they have some characteristics that are not as driver friendly as the 50s IMHO. It does look like they only make the DTC-50 for the Brembo 6 pot brakes though so it's a moot discussion.I did not find DTC 50 at Hawk's page. For my car only available HB802G.661 which is DTC60 (or 70) and DTC30 I believe only for rears. That's why I am saying DTC60, and read in other articles that this is based only on th weight of the car so heating brakes is common and 60/70 are better for temperatures reached. You are mentioning DTC50, where did you find those? Mine is 4 pots front calipers
^^^^^THIS
The stock, 4 piston calipers on the non-PP cars are quite good. The overall brake limitations of your set-up are pad/rotors.
Go with the above recommendations of "1 old racer". At your beginner level this is all you need. You are going to hit your limitations much sooner than you reach your car's limitations.
Just go buy the Brembo's upgrade kit as your rotors will not survive 10 truck days anyway. And get better pads probably G-Loc 10 or something at that regard. The OEM pads are fine but they are expensive.What I want to try next time, before I break the bank with something that I probably don't need at the moment, like a big brake kit upgrade. Is to buy good brake pads and maybe stainless steel brake lines for both front and back, am sure someone has done this brake setup for track use before, and would like to know how was it? which issues arise? recommended actions?
Am planning on taking my car to track around 10 times a year switching pads to OE for street use and for track any suggestions?
In summary would like to know a mid budget friendly set up for my brakes. Rotors, Track Pads, Brakes lines?
In addition the pads that am looking at are Hawk HB802G.661 Front and HB774G.650 Rear
